First off, I play a wide range of games but mainly stick to CS 1.6, Dota 2, Path Of Exile, & Rift on ONE 1920x1080 resolution screen (I use the other for streaming, etc.). My current computer is unable to run Rift with reasonable FPS and maximum settings. With supersampling I get a pitiful 15 fps and with edge smoothing I am able to play but 20-25 fps is definitely not anything to get excited about. Back when I first got the computer and was running CrossFireX I was able to run Metro 2033 at maximum settings and a playable ~32 fps. I would prefer to be able to try games utilizing newer technologies in the foreseeable future at a reasonable fps.
I built this system roughly in Q3 of 2010, so it's been nearly 3 years since I've even payed attention to any new computer-related technology advancements. After landing a steady, fairly well-paying job and receiving a large tax refund for 2013 I have been more and more interested in replacing my computer in its entirety or possibly just parts of it. Unfortunately, after tons of research over the past week or so, it seems technology has not really advanced much with the exception of maybe SSDs and GPUs. However, the more I think about my current setup, the more I realize that what I really want is to get rid of this 30 pound pile of ridiculousness that is the HAF 932 and the headache that is a custom water cooling loop that I don't even fully utilize anymore (despite me not having cleaned it out EVER, partially out of fear of causing a leak and partly out of sheer laziness). But then I realize getting a new case would require removing and reassembling the water cooling loop and that I might as well just replace everything. Now I'm stuck in an endless cycle of indecision.
The new components I have been thinking about:
As you can see here, my goal is to run a computer that is easy to move while attempting to reduce noise in comparison to my current system.
I guess the broader question is:
is it even worth doing a full upgrade at this time? What would you do?
I really don't think I could wait 6-7 months for the new Maxwell cards or 6-12+ months for Broadwell (if it's even going to be that much better than Haswell).
Current System:
CPU: i7 930 (no longer OCed to 4.5GHz, now at 3.0GHz)
HSF: custom dual radiator water cooling loop (~$300)
MBO: Asus Sabertooth X58
RAM: G.Skill 3x2GB PC1600 (F3-12800CL9T-6GBNQ)
GPU: Asus EAH6850 DirectCU (no longer in CrossFire, only using one)
PSU: Seasonic SS-760KM
SSD: ADATA S599 64GB (used ONLY for OS)
HDD: Seagate 500GB ST3500418AS, Samsung F4 2TB ST2000DL004 (Seagate partitioned as 250/250 - 1st partition used for user files and all program installations, 2nd partition for Ubuntu install)
CSE: Coolermaster HAF 932 (full window)
Monitor(s): 2x Acer G235H
CPU: i7 4770K
HSF: Noctua NH-U14S | Corsair H100i ??
MBO: GIGABYTE GA-Z87N-WIFI | EVGA Z87 Stinger | ASRock Z87E-ITX | ASUS MAXIMUS VI IMPACT ????
RAM: G.Skill 2x8GB PC2400
GPU: GTX 770 | GTX 780 | GTX 780 Ti ??
PSU: reuse
SSD: Samsung 840 Evo 250GB
HDD: 2x Hitachi 4TB Deskstar 7K4000
CSE: Corsair 250D
PSU: reuse
CSE: Corsair 250D
