Bust the cardPigCorpse said:Okay
What will happen if I tighten them too much? Is it better than too loose?
Perfect..just hold it up to a light and make sure the cooler is making good contact with the gpu and then you're good to go.PigCorpse said:So I rescrewed it.
I basically turned the screws about 3 turns at a time in the beginning, and in a criss-cross motion. When things got tighter, I turned until I couldn't turn them anymore (without applying strength).
No, it's ok...AS5 takes a while to "cure" so your temps should improve in a day or two.PigCorpse said:Well, I'm kinda retarded a little amount.
I didn't take the card out while doing it. So when the screws were all taken off, I held the fan to the card with my hand. Well, I wasn't holding it over the contact area so I think I might've tilted it because now the temps are 2-3'C higher. I might reapply but I have no AS5 left.
PigCorpse said:Heh, I wish lol.
I didn't actually reseat it. I had to do it quickly before my parents come and tell me to stop working with computers. So I did it while the card was still in the computer. I held the cooler in place and took off the screws and put them back on, but while I was doing that, I think I felt the fan tilt a little, meaning air probably got in.
PigCorpse said:I like fixing things that aren't broken and that tends to make them broken.
