When I first got the 9300-ITX, I wanted to run the IGP along with my 5770 as well. After awhile I disabled the IGP. No need for it at all if you've got a 5770 already unless you have more monitors than the 5770 can support.
It can't be controlled without additional components. You'd need either a fan controller device, or simply buy an "undervolting adapter" to make it run at 7V instead of 12V, for example.
Hmm, I've only seen the setting for the CPU fan. Never for the case fan.
DDR2 is actually a bit more expensive than DDR3 at the moment I think
nvm that _I might have misread something
Is it set to AHCI?
i have no idea. bios setting?
edit: yup.. i installed on ide so i'm not going to bother reinstalling just for esata to work well
Quick question, Can I get a sata to esata cable for an extra HDD and use the power connector from the Power supply to power the Hard drive? Pretty sure the answer would be yes. Just want to check first.
Sata power dude.
