"#$%! The perfect mini-ITX board, and I just discovered a flaw... Damn...Poor NAS solution with only 2 SATA ports. Would make a pretty decent HTPC though.
For an HTPC it's just fine by itself. The 9x00 mGPU is probably the best HTPC chipset at the moment. And, if you don't like it, you can still upgrade later, since it has a full speed PCIe 2.0 16x slot (unlike the only other option on the market, a 780G-based board that's about twice as expensive as this one). The e-SATA port is nice, too.How would this mobo be for a HTPC or a NAS? It might be a little overkill for a nice but it should make for a pretty good HTPC no?
For a NAS you might want to check other options, with more SATA ports. My recomendations are the DG45FC/DQ45EK (same thing, only PCB colour and chipset change, basically) from Intel, and the 8200-ITX from Zotac (for an AMD solution). These are probably the cheapest ones, then you also have Jetway and such, but AFAIK those tend to be much more expensive...
Yes, that's probably better. VIA created the mini-ITX standard, after all...This seems to be good, assuming that pages 19 and 21 are accurate that is.
However, you should be just fine if you take the "uATX with 17x17cm dimention" approach. I have a D945GCLF, and it fit perfectly on a standard ATX case with no problems whatsoever. And yes, before you ask, that case does seem empty when you look at it... hehehe
Oh, right. Now I saw it. Sweeet!As for the ram, it lists compatibility up to 8gb on two slots, so I would assume so.
Cheers.
Miguel
