24" Widescreen CRT (FW900) From Ebay arrived,Comments.
In case you would sell some FW900 parts, please let me know! I am interested.
Likely going to keep a full set of boards for spare parts, but I literally just re-read messages and realized he said he has an extra set of boards for his FW that he's also going to give me. I shouldn't realistically need two full sets of backup boards, so I will keep you posted!
Has any of you tried NvTrueHDR v1.3 modded Retro games on your CRT?
I'm away and can't test it. Heard it looks a lot better than W11 Auto-HDR and gorgeously on organic techs like OLEDs and Plasma. I assumed that's the case with CRTs like F520, FW900, 2070SB, P1130, P275 as well.
Was able to secure another FW900 for parts (damaged tube but boards are supposed to be fine). Only aiming to swap out the S board for now, to see if it brings my dynamic convergence back to life.
Will let you all know how that goes.
Update: The S board has been stuck in Customs for 7 days now. I think they think it's a bomb. Lol.
Edit: It arrived the day after I posted this, and appears to be in pristine condition! Wish me luck with the disassembly, I always hate that part.
I see Startech has a relatively new adapter that uses the Synaptics vmm2322, which is in the Sunix DPU3000 and has the ~545mHz pixel clock
https://media.startech.com/cms/pdfs/mdp2dvid2_datasheet.pdf
Only problem is it's only advertised as a Dual Link DVI adapter. But some of the pictures show it has a DVI-I connector. Maybe it's wishful thinking to believe the analog pins might be wired up?
Then, there are other pictures that show it with a DVI-D connector.
If it doesn't support analog VGA in any of its revisions, I'm wondering if it still might be possible to wire up the 5 analog RGB pins to the chip, then flash it to Sunix firmware.
It's a little too expensive to just buy one just to try. I have to tools to do it though
I bought this after googling that it uses the Synaptics VMM 2322 on Amazon for about £100. I tried my FW900 and a very old Dell LCD panel, i get no picture but they are recognised in windows and Mac OS, meaning the EDID is being passed through. Tempted to open it up and see if maybe the VGA pins simply arent soldered or maybe i got a dud. I already have the cheaper Startech DP2VGAHD20 which works at 1920x1200@80Hz but picture quality is rubbish.
So it does have the DVI-I layout? Some of the pictures I've seen had the DVI-D layout instead
Definitely takes some pictures if you open it up. I'm guessing the analog pins aren't soldered.
Would be really nice if we could find a datasheet for this chip
Yea, thought i could find one easily online but no luck. I will try emailing Synaptics today. Not too keen on opening it yet as it wasnt cheap and if i cant get VGA out of it i’ll have no use for it
Anybody here doing interlacing? 2304x1440i @120hz is pretty darn amazing.
Prefer running 1512x945 @ 120hz and then using Nvidia DLDSR to push the res to 2268*1418 @ 120hz, less faffing about with a secondary card and more compatible imo.
That sounds like a nice alternative res, I'll definitely give that a shot! Already running a 1080ti and have high bandwidth HDMI to VGA dac options, but there are some games that just say "No, I will not let you interlace". Usually just settle with a lower refresh in those cases, but interested in seeing how games take to 1512x945 @ 120hz + DLDSR on my RTX rig.
Hey y'all I just picked up a Sun GDM-5410 which is only a 4:3 but has a whopping 121khz horizontal scan rate letting me push high refresh rates out of this thing. The power works and sends a light to the power button that's blinking orange (instead of green) and the display doesn't appear... There isn't any sound from the guts of the display when I turn it on, but my PC reads it as plugged in at 720p 60hz, more than feasible for this monitor. The cable and PC is good, tested on another CRT. I took it apart and didn't get any voltage from the flyback to the anode, and I'm thinking it's as simple as a bad flyback. This shares the same flyback as the G500 and the FW900, which is why I'm here... Is there anything I could do to make sure it is indeed the flyback before becoming a beggar for some parts? lol
Ah, people and their flyback fancies ... :wacky:
Blinking orange means there's a fault, period. The blinking frequency can give a clue, so does reading the error log in Windas. The issue can be anywhere, and flyback failures may be less than 10% of them.
The person I bought it from showed pictures of it working and said it had worked a week prior, the pictures were of it in the same location in their house so I know they had it working... Could it really be anything if the anode isn't getting voltage?
As soon as the LED is blinking orrange, that means a fault is detected and power supply is shut down. So yes, there won't be any anode voltage, that makes sense. And BTW trying to measure anode voltage is stupidly risky, do you realize it normaly is of several TENs of KILOVOLTS ?
It's green for a couple seconds before going orange blinking, and yeah I didn't try to read the voltage with a tool, I just didn't get an arc when grounding it (while it was unplugged) and removing it from the tube
I've had no reply from Synaptics. I took a closer look at the Startech adapter and as it turns out, the analog pins in the DVI socket arent populated. So at least i know i dont just have a dud.
I find the image quality with the DP2VGAHD2 to be quite pleasing. Bought a spare or two.
Using this resolution on the FW900.
How's y'alls fw geometry? I've owned a fair few and find they either have slight bowing along the top and bottom or are basically laser accurate.
I'm the oddball running 2235 x 1397 @ 83Hz calculated to 375Mhz pixel clock. No flickering and silky smooth when locked to refresh rate. I'm also on the StarTech DP2VGAHD20, and I do have a spare just in case.
My man. Another reason CRT rocks. It will draw whatever you tell it to, provided it's in range.
How do you do it ? Nvidia control panel doubles the bandwidth, making it impossible, and, CRU adds it, but, when I click apply on the CP nothing happens.
How do you do it ? Nvidia control panel doubles the bandwidth, making it impossible, and, CRU adds it, but, when I click apply on the CP nothing happens. (sorry for spam... been looking forward to a reply from someone...now impatiently haha)
Nvidia gives you options as to which timing formula to use. I had good results using the GTF formulas, if I recall correctly:
Timings are either CVT or GTF. CVT always works fine, I seem to remember for GTF it depends on the resolution.
A few days ago I got my hands on a Intel ARC A380, so I could test interlaced resolutions support by myself. I found no real reports out there, and some contradictory informations on that.
I did a complete writeup on Reddit, I don't know if I'm allowed to post these links here, I'll try.
https://www.reddit.com/r/crtgaming/comments/1c0w4w3/interlaced_on_intel_arc_a380_sort_of_working/
Short version here, no support at all on the latest drivers (31.0.101.5382), but when I tried the very first drivers supporting the A380 (30.0.101.1736), interlaced resolutions works!
It looks like HDMI caps at 1080i60. After that the resolutions just don't show up anymore in Windows. Might be error on my part, but I had a bunch of issues with the HDMI port, even on LCD displays, so I just moved to DisplayPort for further testing.
On DisplayPort though, any interlaced resolution entered in CRU shows up in the Windows display settings. Issue is, there is a limitation around 220MHz pixel clock or so, where the picture starts to get messed up from the bottom, all the way to the top the higher the pixel clock.
I was able to make the following resolutions work flawlessly:
  • 1920x1440i, the highest 100% working refresh rate was 110.33Hz (221.71MHz pixel clock)
  • At 1600x1200i, it was 154.46Hz (223.63MHz pixel clock, a bit higher for some reason, limitation might not be pixel clock then)
  • Also tested 2880x1800i at 60Hz, working fine very close to the Intel ARC limit as well (still far from the monitor limit of 140Hz...)
So, glad to see it somewhat works, but considering the limitations it's totally pointless to me. While 110Hz at 1920x1440 is still better than the 90Hz my F520 can do in progressive, it's really not much of a difference, and the drawbacks of interlaced completely negate the gain in refresh rate here, making it a worse resolution.
So, by far, I would rather use 1920x1440 at 90Hz progressive than 110Hz interlaced. In the current state of things, while ARC supports interlaced, it might only be interesting for people wanting to run lower resolutions, maybe driving a 1080i HD CRT TV, or maybe 480i (didn't test that yet...).
So this was an interesting test for sure, glad I was finally able to get those infos. At least we know ARC hardware supports interlaced, unlike what Intel claims (see Note section below). It's once again a driver issue...
But I don't think any future update will change that. And I'm a bit worried about 15th gen Intel CPUs, but I guess I'm gonna give it a test when it's released.
(https://www.intel.com/content/www/us/en/support/articles/000094488/graphics.html)
Next up, I'm expecting a delivery of a Asus B660-I motherboard early next week, with a temporary Intel Pentium G7400 (Intel UHD 710, same driver as the 770 found in the higher end i5 - i9).
I heard a few reports of interlaced working on the iGPU, but again with previous driver versions. It should not be a problem, so I'm gonna give this a try and figure out what the limits are.
If I can finally run 1920x1440i at 170Hz with these iGPUs, I will throw my RTX 4060 Low Profile on it, and start testing some recent games at high res, and soon get a proper CPU (since it's gonna be in a tiny case, probably the i5 13600K).
I will report back when I'm done testing.
If I remember correctly, Nvidia will show double bandwidth in the UI, but when it actually displays the resolution, it will output the correct (meaning half) bandwidth
CVT didn't work either... thanks for your replies though
Sorry for the late reply. Nvidia's DLDSR will only work on the highest currently available resolution, so I have several preset CRU bins with my desired resolutions and refresh rates.
I tend to swap between different resolutions depending on the game I’m playing.
For example, I’m currently playing Persona 3 Reloaded on Xbox Game Pass, which supports 120Hz. This gives me two options: I can load up my CRU with only 1512*945 @ 120Hz (no other resolutions). I actually find this resolution perfectly fine for P3R. However, I can bump this up via Nvidia DLDSR by going into the Nvidia Control Panel, selecting "Manage 3D Settings," and under DSR – Factors, choosing DL scaling 2.25x.
This should enable a resolution of 2268*1418 @ 120Hz.
You can either leave the desktop at 1512*945, as the new resolution should be selectable in-game now, or just use the new resolution straight away if the game doesn’t recognize it.
Tip: Make sure the resolution that you want to upscale is the highest available resolution. Also, when I'm gaming on the FW900, I tend to set that screen as the main screen.
I have attached a zip file with the pre-made CRU bins, along with a list highlighting the refresh rates at natural resolutions and their corresponding DLDSR resolutions to help you make your choice.
Most of the CRU bins work fine on the Delock 62967; however, the 2800+ resolutions only work on the LK7112 – the Delock caps out at 2700 at 60Hz, but your mileage might vary. The 160Hz options should include 640*400, which is perfect for Sea of Stars.
So yeah, I find these bins perfect for me. I can switch to the best 60Hz option for games that are locked to 60Hz, and other options depend on whether my 3080Ti can hit those frames per second, and then use DLDSR as a fallback if I want to explore higher ress’s
  • DLDSR.rar
Alright, here it is! Today I was finally able to test the last gen Intel integrated graphics with interlaced modes.
This time I went straight to DisplayPort, tried with the default drivers installed by Windows Update and as expected... no interlacing working. No surprise there.
So I went straight to DDU to remove these and downgrade to a random version 30.0.101.207 I found online. My thought were version 31 seems to have dropped interlaced, so probably version 30.whatever would work. Sure enough, that works!
With ARC I was limited to 110Hz on 1920x1440 interlaced, but here... it went up to 170Hz without the slightest issue! Working perfectly, awesome! What a relief!
Now it was time to test higher resolutions, and find the limits. I remember with my Intel 9700K I couldn't display high resolutions, the horizontal pixels count was capped if I'm not mistaken. So I was expecting something similar here.
But to my surprise... I was able to display a whopping 4080x2550i (16:10) at 62Hz!! Or more realistically maybe, 2200x1650i (4:3) at 165Hz for example. And I tried 4K 16:9, 3840x2160i at 77Hz. I suppose 72Hz would be best for multimedia playback.
Absolutely mindblowing! I always wanted to have access to interlaced resolutions that high, so I could display stuff like 4K. Especially with the already crazy high 540MHz bandwidth of the Sunnix DPU3000, there is a lot of room for high resolutions at really good refresh rates if using interlaced!
Now, unfortunately, there is still a limitation as usual. Here, pixel clock is precisely capped at 458.49MHz on DisplayPort. Going just one decimal over, and the custom resolution won't show up anymore. I tested that exact limit for a few different resolutions, it remains the same.
HDMI is just super limited once again, I can't go over 1080i 60 or something. I didn't test much longer and didn't look for exact limits, it looked pointless to me.
So I'm curious if maybe ToastyX could work something out for Intel drivers, if he gets access to the hardware. That would be insane if the limit could be lifted here, allowing the full bandwidth of the adapters on both progressive and interlaced resolutions! Maybe lift the HDMI limit too, I don't know.
Note that, at such high resolutions like 4K, the odd and even lines are literally almost on top of each other, and you just can't see it's interlaced anymore. I looked very close and couldn't tell it was interlaced.
Also, it's crazy that at 4080x2550i on my GDM-F520, setting the Windows UI scaling to 100%... I was still just barely able to read fine texts in the Windows Settings app, looking close at the screen. It's super tiny, it's just barely readable, but you can see the F520 is the sharpest Trinitron tube, and it shows! I haven't tested on the FW900 yet.
Now, to me this is the best solution I've ever tried, for using interlaced on a recent PC. I really dislike the last gen Intel CPUs sadly, and would much rather wait for next gen AMD & Intel... But with results like that, I'll be getting a 13/14th gen i5 or i7 i5 13600K very soon.
One more thing I need to test, is actually playing at high resolution and refresh rates with a rendering GPU passing frames to the iGPU for display. It's not great to test that with a super slow Intel Pentium Gold, but I'm sure I can try older games it will have lots of fps. Hopefully something doesn't bottleneck here, but I'll find out I guess.
Big compromise with this solution though... Now I'm stuck with a CPU generation, which is why I really hoped Intel ARC would be just as good... So I could upgrade to Intel 15th gen or the next gen Ryzen, and just plug in ARC and keep going. Now I can't upgrade, at least not this PC.
I'm not sure Intel 15th gen iGPU will have similar behavior, considering even current gen has no more interlaced support with recent drivers. I really don't understand that, it was working so well, why just remove it with an update like that?
It's weird because they say interlaced works on their iGPUs, when it really doesn't with the latest drivers. Maybe it's gonna come back with a future update, no idea. I would be very curious to test a 15th gen CPU.
Today I hooked up the FW900 to the Intel iGPU, and 3840x2400i at 72Hz looks absolutely stunning on it! I had to tweak the timings a little to get below the 458.49MHz limit, but it worked flawlessly. Crystal clear picture!
With only 90.1kHz and 72Hz, it's far from the maximum limits of this monitor, which is quite impressive with such a high resolution already!
I watched a couple episodes of Loki on it! :D
i love you
The fantastic FW900 does not disappoint.
I'm not looking to upscale, just looking to interlace
I really hope someone here has a solution. I've spent 12 hours today trying to solve this issue.
I read here and on Reddit about how Intel iGPUs can do interlacing, so I bought a new motherboard and an i5 13600k to use interlacing on my IBM P275. I have a 6900 XT as well that I'm using. Set it up and made some interlaced resolutions. I was blown away by the clarity at 2400 x 1800i at 120 Hz. Played Helldivers 2 and had a great time. Thought I would try Halo and it unfortunately went to black screen. Wasn't sure what that was about but after that, every game that I've tried it crashes. My PC just will not switch from my iGPU to my 6900 XT. Just to clarify, Windows 11 lets you choose which GPU you want to use. I was connected to my IGPU, using it to display interlaced resolutions while the games render on my 6900 XT.
It doesn't matter if I tell it which specific GPU in the Windows graphics settings. It just doesn't work. I uninstalled and reinstalled both Intel and AMD drivers. Tried multiple different versions of each. It will not work. It will start the games if I specify iGPU but will not use the 6900 XT. I can't switch in the middle of a game either.
Looked for BIOS settings, tried changing the iGPU to primary. That didn't work. Downloaded the latest motherboard drivers. Didn't work. It's the same black screen everytime. GPU fans don't spin. For some reason the iGPU is not communicating to the 6900XT anymore.
Again, it did work initially but after a crash it hasn't worked again.
Anyone have any ideas? My last resort is a Windows reinstall but I really would prefer not, as I have SSDs full of family videos and pictures I would have to deal with. I'm not even sure if this would solve the issue?
