I've not been able to give my build parallel HEX the time it deserves lately due to work and other stuff, but now's the time!
I'll be placing my order for my AC components tonight, but I need a plan B if I screw up the modification to the cuplex XT to 3 ports like I originally suggested here.
So I'm looking for suggestions on other 3 port CPU blocks. The prerequisites are it's for an AMD X2 cpu, and the fittings must be able to be replaced.
Someone suggested the DD RBX on my project log, and it is a good suggestion but I have a few questions I couldn't find the answers for:
1. what is the thread size/type of the RBX fittings? Are they 1/2" BSPT, NPT for example.
2. is it worth getting the nozzle pack, and if so, what nozzle do you use? The ProCooling site says #4 and #5 are best for the TDX, does this equate to the RBX too?
3. will using 'low flow' tubing (6mm ID) have any ill effects? Can't see any, but worth asking none-the-less!
In case you haven't gathered from those questions I'll be replacing the stock fittings with quick fittings (hate to use barbs unless I really have too, pump etc).
