greeneye
- Jun 29, 2007
Hello,
I'm after some educational and helpful advice on a proper liquid cooling setup.
I'm currently using a Corsair H50 and i feel that its not doing enough for me. I hate temperatures over 55*c on my CPU and I really would like to go much higher on the overclock, along with my GPU (Stock fan cooler)
Now im after some information on what I should probably choose for a radiator, pump, tubing and a waterblock. Iv'e already ordered a Swiftech Hi-Flo Acrylic Reservior Rev-2 because I originally wanted to 'Mod' my H50.
I have very little idea on what hardware i need to pick for some decent temperature results. But i have a fairly decent idea on installation.
My case dosent have the best room for a triple-sized radiator + pump. [Fractal Design Define R2], so I saw a MCR220 heat drive exchanger going for a decent price [Intergrated Pump - MCP350, Intergrated Resovior and 2x 120mm fan slots/size]
Or should I go for a complete WC system - Radiator, Pump, Waterblock, Resovior.
This will be the first ive installed a main-proper WC system (H50/H70 is way to simple for my likings.. and isn't changable like a proper WC system).
I can probably run a triple sized radiator on the top of my case wich is fine (MCR320 Heat Drive Exchanger is also available for this size), because i would like to setup CPU, Mobo (if its still efficent enough) and GPU.
Eventually once i get the hang of WC and setting up nicely i will end up going all out and having all bits in the case. But if this MCR220/MCR320 heat drive exchanger isn't exactly a improvement then i will go all out on seperate items.
And im after any other advice that i should be aware of from setting up my first WC setup.
Thanks
Thanks
