stats:
E5200
4GB Wintec RAM
Zotac 630i-ITX WiFi
Fujitsu HDD
Dual Prime blend and Memtest are both 24 hour stable. Temps aren't an issue. Random BSOD's, and here's my latest dump:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\101809-20482-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02c4d000 PsLoadedModuleList = 0xfffff800`02e8ae50
Debug session time: Sun Oct 18 17:56:01.671 2009 (GMT-4)
System Uptime: 1 days 6:43:29.860
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {fffff80003cfbe10, 1, fffff80002df1991, 2}
Could not read faulting driver name
Probably caused by : win32k.sys ( win32k!AllocateW32Process+4a )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff80003cfbe10, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff80002df1991, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ef50e0
fffff80003cfbe10
FAULTING_IP:
nt!ExAllocatePoolWithTag+5c1
fffff800`02df1991 488910 mov qword ptr [rax],rdx
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff88001fe4830 -- (.trap 0xfffff88001fe4830)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff80003cfbe10 rbx=0000000000000000 rcx=fffff88003cfbe10
rdx=fffff900c1b3c340 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002df1991 rsp=fffff88001fe49c0 rbp=fffff88003cfbcc0
r8=0000000000000021 r9=fffff88003cfc140 r10=fffff88003cfbcc8
r11=000007fffffac000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
nt!ExAllocatePoolWithTag+0x5c1:
fffff800`02df1991 488910 mov qword ptr [rax],rdx ds:0010:fffff800`03cfbe10=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002d3cbc2 to fffff80002cbef00
STACK_TEXT:
fffff880`01fe46c8 fffff800`02d3cbc2 : 00000000`00000050 fffff800`03cfbe10 00000000`00000001 fffff880`01fe4830 : nt!KeBugCheckEx
fffff880`01fe46d0 fffff800`02cbcfee : 00000000`00000001 fffff900`c1b3c000 fffffa80`05e17000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x40f90
fffff880`01fe4830 fffff800`02df1991 : 00000000`00000000 fffff880`01fe4a01 00000000`746c6644 fffff880`01fe4a70 : nt!KiPageFault+0x16e
fffff880`01fe49c0 fffff800`02cdfd06 : 00000000`00000000 00000000`00000029 fffffa80`05c5b060 fffff800`00000000 : nt!ExAllocatePoolWithTag+0x5c1
fffff880`01fe4ab0 fffff960`0018fa52 : fffffa80`05e17060 00000000`00000000 00000000`00000000 fffff800`02f8f7b6 : nt!ExAllocatePoolWithQuotaTag+0x56
fffff880`01fe4b00 fffff960`00184aaa : 00000000`00000000 fffffa80`05e17060 00000000`00000000 00000000`00000000 : win32k!AllocateW32Process+0x4a
fffff880`01fe4b30 fffff960`001880b8 : 00000000`00000000 00000000`00000002 00000000`00000002 fffff800`02ccb04b : win32k!xxxSetProcessInitState+0x2a
fffff880`01fe4b60 fffff960`00187fd6 : 00000000`00000002 00000000`000003e4 00000000`00000b08 00000000`00000000 : win32k!xxxUserNotifyProcessCreate+0xbc
fffff880`01fe4bb0 fffff800`02cbe153 : fffffa80`05c5b060 fffff880`01fe4c60 00000000`00000000 00000000`00000000 : win32k!NtUserNotifyProcessCreate+0x5e
fffff880`01fe4be0 000007fe`fd7613aa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0233f528 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fd7613aa
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff960`0018fa52 488bd8 mov rbx,rax
SYMBOL_STACK_INDEX: 5
SYMBOL_NAME: win32k!AllocateW32Process+4a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc5e0
FAILURE_BUCKET_ID: X64_0x50_win32k!AllocateW32Process+4a
I have updated the BIOS, and every driver, but still BSOD. What else should I check? The most strenuous thing this machine does is run a web browser.
E5200
4GB Wintec RAM
Zotac 630i-ITX WiFi
Fujitsu HDD
Machine Name:
0: kd> !analyze -v
Arguments:
address.
Debugging Details:
fffff80003cfbe10
FAULTING_IP:
MM_INTERNAL_CODE: 2
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: win32k
