faugusztin
- Mar 9, 2008
I'm planing to buy P182 as a replacement for my Antec Solo, and the main question is if the 8-pin cable is long enough for auxiliary CPU power connector placed on top of motherboard (Asus P5K-E/WIFI-AP). Did anyone tried this (or similar) setup ? If not, can anyone measure how long must be that cable from PSU to the upper hole in upper corner near the back of case ?
The second (not so important) question is - how good is this case for cooling HD3870 (with passive Accelero S1) and E6750 (cooled by Thermalright Ultra-120 Extreme with Noctua NF-P12) ? I'm planing to have one or two Nexus fans in upper chamber (at the back/top), maybe one Nexus fan in PSU/HDD chamber.
Thanks for all responses.
Edit: And maybe most important - can i close door when Zalman MFC1 Plus or Scythe KM01-BK "KAZE MASTER" 5.25" Bay Fan Controller ? P5K-E/WIFI-AP is rather bad in terms of controlling fan speed (CPU fan is not controllable at all, other 3 fans can be regulated only together), so there is a need for external regulation in case of this board.
