WickedWeasel
- Jul 13, 2004
Is there a case that is very similar to the Antec Solo. It should be the same height, but a bit wider to accomodate 2 front intake 120mm fans, and is a bit longer to fit in an 8800GTX, but will be made of steel and have insulated side panels for sound proofing.
If antec made such modifications to the Solo, it would be the perfect case.
