snowysnowcones
- Apr 2, 2006
Hi everybody,
I believe my DVI ports are broken on my Sapphire Radeon X1950GT. I'm using a DVI to VGA adapter to hook it up to my monitor. Unfortunately, when I use one of them, I get semi-transparent white diagonal lines (at about a 65 degree angle) going from the bottom right, moving to the top left. It's most noticeable on a dark background, especially if there's a gradient involved. (On web-pages). The other DVI port gives me slightly blurry text every few letters. I've tried this on both DVI to VGA adapters, and they give me the same result. Are my DVI ports broken?
System specs:
CPU: Intel Core 2 Duo e4300
VGA: Sapphire Radeon X1950GT
Motherboard: Biostar T-Force P35
RAM: Crucial Ballistix DDR2 Tracer 2 (2x1)gb.
Operating System: Windows Vista 32bit.
Any help would be greatly appreciated!
-Snowy
System specs:
-Snowy
