ARECA Owner's Thread (SAS/SATA RAID Cards)
Hi everyone, I'm new to this forum and have some questions about ARC-1883i.
I'm running Windows 10 as a NAS, 6 Seagate SATA EXOS 20 TB in RAID6 on the ARC1883i.
System is running fine, but I'm trying to put the HDD's into standby.
Under "System Controls > Hdd Power Management > Time To Spin Down Idle HDD" to 30 (Min) and it worked fine.
BUT after a while the array wakes up from "spun down" without any direct access.
The typical background task software like AIDA64 or any other S.M.A.R.T. software is not installed.
I could not find a solution in this forum but maybe there are some user who are experienced with these setting or problem?
Is there any chance to set the array permanently to "sleep" ??
It is most likely something on the network (or even the local machine) is polling the shared drive which forces it to wake to respond. If you pull the Ethernet cable, does the problem resolve (easy way to see if it is coming from the local network or the local machine itself?)
That's good - I will try it and let know.
Hi everyone. I'm hoping that this crew will have the info I desperately need.
I was in the process of migrating data from one raid volume to a new (larger capacity) volume. During this process, I had several drives fail in my original volume. I offlined the original volume until I was able to identify what was happening. I read that after you offline the volume that you need to remove the drives and reseat them in order for the arc-1880 to repick them back up.
After doing this, I found that instead of recovering the original set, it formed two different sets (each with only 2 disks of 6). The 3 drives removed were 1 global spare, 2 drives from the original R6.
Is there a way to recover this original Raid6 of these Hitachi drives?
Code:
CLI> rsf info
 #  Name                     Disks      Total       Free  State
 1  Raid Set # 000               6  12000.0GB      0.0GB  Degraded
 2  Raid Set # 000               6  12000.0GB      0.0GB  Degraded
 3  Raid Set # 001               4  32000.0GB      0.0GB  Normal
CLI> rsf info raid=1
Raid Set Information
Raid Set Name        : Raid Set # 000
Member Disks         : 6
Total Raw Capacity   : 12000.0GB
Free Raw Capacity    : 0.0GB
Min Member Disk Size : 2000.0GB
Supported Volumes    : 16
Raid Set Power State : Operating
Raid Set State       : Degraded
Security Status      : ISE Disks
Member Disk Channels : x.E2S9.x.x.E2S5.x.
CLI> rsf info raid=2
Member Disks         : 6
Member Disk Channels : x.x.E2S10.E2S11.x.x.
CLI> vsf info
  # Name             Raid Name       Level   Capacity Ch/Id/Lun  State
  1 ARC-1880-VOL#000 Raid Set # 000  Raid6   8000.0GB 00/00/00   Failed
  2 ARC-1880-VOL#001 Raid Set # 001  Raid6   16000.0GB 00/00/01   Normal
  3 ARC-1880-VOL#000 Raid Set # 000  Raid6   8000.0GB 00/00/00   Failed
CLI> vsf info vol=1
Volume Set Information
Volume Set Name   : ARC-1880-VOL#000
Volume Serial     :
Volume Capacity   : 8000.0GB
SCSI Ch/Id/Lun    : 00/00/00
Raid Level        : Raid6
Stripe Size       : 16K
Member Disks      : 6
Cache Mode        : Write Back
Write Protection  : Disabled
Volume Encryption : Non-Encrypted
IO Mode           : Cached IO
Tagged Queuing    : Enabled
Volume State      : Failed
CLI> vsf info vol=3
Volume Serial     :
Raid Level        : Raid6
Stripe Size       : 16K
Member Disks      : 6
IO Mode           : Cached IO
CLI> disk info
  # Enc# Slot#   ModelName                        Capacity  Usage
  1  01  Slot#1  N.A.                                0.0GB  N.A.
  2  01  Slot#2  N.A.                                0.0GB  N.A.
  3  01  Slot#3  N.A.                                0.0GB  N.A.
  4  01  Slot#4  N.A.                                0.0GB  N.A.
  5  01  Slot#5  N.A.                                0.0GB  N.A.
  6  01  Slot#6  N.A.                                0.0GB  N.A.
  7  01  Slot#7  N.A.                                0.0GB  N.A.
  8  01  Slot#8  N.A.                                0.0GB  N.A.
  9  02  SLOT 01 WDC WD80EFBX-68AZZN0             8001.6GB  Raid Set # 001
 10  02  SLOT 02 N.A.                                0.0GB  N.A.
 11  02  SLOT 03 N.A.                                0.0GB  N.A.
 12  02  SLOT 04 N.A.                                0.0GB  N.A.
 13  02  SLOT 05 Hitachi HDS5C3020ALA632          2000.4GB  Raid Set # 000
 14  02  SLOT 06 WDC WD80EFBX-68AZZN0             8001.6GB  Raid Set # 001
 15  02  SLOT 07 WDC WD80EFBX-68AZZN0             8001.6GB  Raid Set # 001
 16  02  SLOT 08 WDC WD80EFBX-68AZZN0             8001.6GB  Raid Set # 001
 17  02  SLOT 09 Hitachi HDS5C3020ALA632          2000.4GB  Raid Set # 000
 18  02  SLOT 10 Hitachi HDS5C3020ALA632          2000.4GB  Raid Set # 000
 19  02  SLOT 11 Hitachi HDS5C3020ALA632          2000.4GB  Raid Set # 000
 20  02  SLOT 12 N.A.                                0.0GB  N.A.
 21  02  EXTP 01 N.A.                                0.0GB  N.A.
 22  02  EXTP 02 N.A.                                0.0GB  N.A.
 23  02  EXTP 03 N.A.                                0.0GB  N.A.
 24  02  EXTP 04 N.A.                                0.0GB  N.A.
Code:
CLI> rsf info
Member Disks         : 6
Member Disks         : 6
CLI> vsf info
CLI> vsf info vol=1
Volume Serial     :
Raid Level        : Raid6
Stripe Size       : 16K
Member Disks      : 6
IO Mode           : Cached IO
CLI> vsf info vol=3
Volume Serial     :
Raid Level        : Raid6
Stripe Size       : 16K
Member Disks      : 6
IO Mode           : Cached IO
CLI> disk info
First, please post the complete log from the card. Are the drives still in their original drive order? Next, you mentioned (2 drives of 6) did you originally have a 4 drive R6 of 2TB drives, which you were migrating the data to a second 4 drive R6 of 8TB drives? Do you just need to recreate the data on the 2TB drives (meaning you have 8TB drives (which have no data you currently need) you can use to backup the 2TB drive images to so you can attempt repair on the mirrors without damaging the original data in case different attempts fail?
Thank you for the reply. Allow me to clarify:
I was in the process of migrating the data away from a 6x 2TB R6 (+1 Spare) and onto a 4x 8TB R6. During this process, I had a single drive fail. This caused the spare to begin rebuilding. Then the spare failed, followed by yet another disk.
At that point I stopped the copy process. I then was worried of losing another disk, so I offlined the raid. I then removed all the disks, sorted out the failed ones and put back the operational drives. I believe they're in the correct slots.
Once I put them back and brought the server online, it appeared to be in this state. I may have gotten the drives in the wrong order?
I'd be happy to produce a log, but where do I get that from?
Based upon what you stated you only have 2 members of a R6 fail (the first two which were array members, and the spare which had not yet been graduated to an array member,) which while not leaving your any parity should (if there are no other issues) leave you the ability to activate and/or repair the array. As to the log, you can get it through McBIOS or ethernet in Raid System Console -=> System Controls -=> View Events.
I believe this might be what you're after...
Please let me know if there is anything else I can grab for you:
Code:
CLI> main
Copyright (c) 2004-2018 Areca, Inc. All Rights Reserved.
Areca CLI, Version: 1.15.8, Arclib: 373, Date: May 29 2018( Linux )
 S  #   Name       Type             Interface
[*] 1   ARC-1880   Raid Controller  PCI
CMD     Description
main    Show Command Categories.
set     General Settings.
rsf     RaidSet Functions.
vsf     VolumeSet Functions.
disk    Physical Drive Functions.
sys     System Functions.
adsys   Advanced System Functions.
hddpwr  Hdd Power Management.
net     Ethernet Functions.
event   Event Functions.
hw      Hardware Monitor Functions.
mail    Mail Notification Functions.
snmp    SNMP Functions.
ntp     NTP Functions.
sef     Security Functions.
exit    Exit CLI.
CLI> event info
Date-Time            Device           Event Type            Elapsed Time Errors
2024-01-26 18:06:42  H/W MONITOR      Raid Powered On
2024-01-26 17:55:36  RS232 Terminal   VT100 Log In
2024-01-26 17:55:13  H/W MONITOR      Raid Powered On
2024-01-26 17:49:57  H/W MONITOR      Raid Powered On
2024-01-26 17:38:07  Enc#2 SLOT 12    Device Removed
2024-01-26 17:36:59  Enc#2 SLOT 04    Device Removed
2024-01-26 17:36:44  Raid Set # 000   Offlined
2024-01-26 17:33:10  Enc#2 SLOT 02    Device Removed
2024-01-26 17:32:52  Raid Set # 000   Offlined
2024-01-26 17:32:21  SW API Interface API Log In
2024-01-26 17:30:43  Enc#2 SLOT 03    Device Removed
2024-01-26 17:28:50  Enc#2 SLOT 09    Device Removed
2024-01-26 17:28:07  Enc#2 SLOT 10    Device Removed
2024-01-26 17:27:32  Enc#2 SLOT 11    Device Removed
2024-01-26 17:24:41  Raid Set # 000   Offlined
2024-01-26 17:24:27  Raid Set # 000   Offlined
2024-01-26 17:24:19  SW API Interface API Log In
2024-01-26 17:14:10  H/W MONITOR      Raid Powered On
2024-01-26 17:11:55  Raid Set # 000   Offlined
2024-01-26 17:11:42  Raid Set # 000   Offlined
2024-01-26 17:11:27  RS232 Terminal   VT100 Log In
2024-01-26 17:11:15  H/W MONITOR      Raid Powered On
2024-01-26 15:48:45  H/W MONITOR      Raid Powered On
2024-01-26 15:43:23  H/W MONITOR      Raid Powered On
2024-01-26 15:34:18  H/W MONITOR      Raid Powered On
2024-01-26 15:30:44  H/W MONITOR      Raid Powered On
2024-01-26 15:28:18  RS232 Terminal   VT100 Log In
2024-01-26 15:27:58  H/W MONITOR      Raid Powered On
2024-01-26 15:26:51  Raid Set # 000   Rebuild RaidSet
2024-01-26 15:26:50  Enc#2 SLOT 03    Device Inserted
2024-01-26 15:24:48  Enc#2 SLOT 03    Device Removed
2024-01-26 15:24:48  Raid Set # 000   RaidSet Degraded
2024-01-26 15:24:48  ARC-1880-VOL#000 Volume Failed
2024-01-26 15:23:49  Raid Set # 000   Offlined
2024-01-26 15:23:37  Raid Set # 000   Offlined
2024-01-26 15:23:22  RS232 Terminal   VT100 Log In
2024-01-26 15:23:03  H/W MONITOR      Raid Powered On
2024-01-26 15:21:24  RS232 Terminal   VT100 Log In
2024-01-26 15:20:48  H/W MONITOR      Raid Powered On
2024-01-26 14:55:48  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:48  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:47  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:47  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:47  ARC-1880-VOL#000 Volume Degraded
2024-01-26 14:55:41  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:41  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:40  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:40  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:40  ARC-1880-VOL#000 Volume Degraded
2024-01-26 14:55:34  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:34  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:33  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:33  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:26  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:26  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:55:16  Raid Set # 000   RaidSet Degraded
2024-01-26 14:55:16  ARC-1880-VOL#000 Volume Failed
2024-01-26 14:50:32  RS232 Terminal   VT100 Log In
2024-01-26 14:50:31  Enc#2 SLOT 04    Device Inserted
2024-01-26 14:50:28  Enc#2 SLOT 03    Device Inserted
2024-01-26 14:50:25  Enc#2 SLOT 02    Device Inserted
2024-01-26 14:50:15  Enc#2 SLOT 12    Device Inserted
2024-01-26 14:50:11  Enc#2 SLOT 11    Device Inserted
2024-01-26 14:50:07  Enc#2 SLOT 10    Device Inserted
2024-01-26 14:50:01  Enc#2 SLOT 09    Device Inserted
2024-01-25 22:56:53  Enc#2 SLOT 05    Device Inserted
2024-01-25 22:56:26  Enc#2 SLOT 03    Device Removed
2024-01-25 22:55:18  Enc#2 SLOT 04    Device Removed
2024-01-25 22:55:03  Enc#2 SLOT 02    Device Removed
2024-01-25 22:54:48  Enc#2 SLOT 01    Device Removed
2024-01-25 22:53:24  Enc#2 SLOT 12    Device Removed
2024-01-25 22:53:08  Enc#2 SLOT 11    Device Removed
2024-01-25 22:52:42  Enc#2 SLOT 10    Device Removed
2024-01-25 22:52:05  Enc#2 SLOT 09    Device Removed
2024-01-25 22:40:05  RS232 Terminal   VT100 Log In
2024-01-25 22:39:31  H/W MONITOR      Raid Powered On
2024-01-25 22:30:36  H/W MONITOR      Raid Powered On
2024-01-25 22:06:40  Enc#2 SLOT 02    Time Out Error
2024-01-25 22:06:12  Enc#2 SLOT 10    Time Out Error
2024-01-25 22:05:44  Enc#2 SLOT 10    Time Out Error
2024-01-25 22:05:17  H/W MONITOR      Raid Powered On
2024-01-25 21:52:33  Raid Set # 000   RaidSet Degraded
2024-01-25 21:52:33  ARC-1880-VOL#000 Volume Failed
2024-01-25 21:52:23  Enc#2 SLOT 11    Time Out Error
2024-01-25 21:52:23  Enc#2 SLOT 10    Time Out Error
2024-01-25 21:52:23  Enc#2 SLOT 09    Time Out Error
2024-01-25 21:52:23  Enc#2 SLOT 01    Time Out Error
2024-01-25 21:51:51  Enc#2 SLOT 09    Time Out Error
2024-01-25 21:51:50  Enc#2 SLOT 01    Time Out Error
2024-01-25 21:51:22  Enc#2 SLOT 09    Time Out Error
2024-01-25 21:50:54  Enc#2 SLOT 01    Time Out Error
2024-01-25 21:49:53  Enc#2 SLOT 01    Time Out Error
2024-01-25 21:49:20  Enc#2 SLOT 10    Time Out Error
2024-01-25 21:48:52  Enc#2 SLOT 09    Time Out Error
2024-01-25 21:48:25  H/W MONITOR      Raid Powered On
2024-01-25 21:37:35  SW API Interface API Log In
2024-01-25 21:17:14  Raid Set # 000   Offlined
2024-01-25 21:17:06  SW API Interface API Log In
2024-01-25 20:58:27  SW API Interface API Log In
2024-01-25 20:56:30  H/W MONITOR      Raid Powered On
2024-01-25 19:35:53  Enc#2 SLOT 10    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 01    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 11    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 09    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 10    Device Failed
2024-01-25 19:35:53  Enc#2 SLOT 08    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 07    Device Removed
2024-01-25 19:35:53  Enc#2 SLOT 06    Device Removed
2024-01-25 19:35:52  Raid Set # 000   RaidSet Degraded
2024-01-25 19:35:52  Enc#2 SLOT 04    Device Removed
2024-01-25 19:35:52  Enc#2 SLOT 03    Device Removed
2024-01-25 19:35:52  Enc#2 SLOT 02    Device Removed
2024-01-25 19:35:52  ARC-1880-VOL#000 Volume Failed
2024-01-25 19:35:52  Enc#2 SLOT 12    Device Removed
2024-01-25 19:35:51  Enclosure#2      Removed
2024-01-25 19:35:29  Raid Set # 000   RaidSet Degraded
2024-01-25 19:35:29  ARC-1880-VOL#000 Volume Failed
2024-01-25 19:35:06  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:35:00  Enc#2 SES2Device Time Out Error
2024-01-25 19:34:05  Enc#2 SES2Device Time Out Error
2024-01-25 19:33:22  Enc#2 SES2Device Time Out Error
2024-01-25 19:33:09  Enc#2 SES2Device Time Out Error
2024-01-25 19:32:27  Enc#2 SES2Device Time Out Error
2024-01-25 19:32:15  Enc#2 SES2Device Time Out Error
2024-01-25 19:31:33  Enc#2 SES2Device Time Out Error
2024-01-25 19:31:31  SW API Interface API Log In
2024-01-25 19:31:20  Enc#2 SES2Device Time Out Error
2024-01-25 19:30:56  Enc#2 SLOT 12    Device Failed
2024-01-25 19:30:55  ARC-1880-VOL#000 Abort Rebuilding      000:10:17
2024-01-25 19:30:55  Raid Set # 000   RaidSet Degraded
2024-01-25 19:30:55  ARC-1880-VOL#000 Volume Degraded
2024-01-25 19:30:46  Enc#2 SLOT 12    Time Out Error
2024-01-25 19:29:45  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:29:37  Enc#2 SLOT 04    Device Failed
2024-01-25 19:29:14  Raid Set # 000   RaidSet Degraded
2024-01-25 19:29:14  ARC-1880-VOL#000 Volume Degraded
2024-01-25 19:29:05  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:29:05  Enc#2 SLOT 09    Time Out Error
2024-01-25 19:29:05  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:29:05  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:28:55  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:28:55  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:28:55  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:28:45  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:28:35  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:28:26  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:28:26  Enc#2 SLOT 09    Time Out Error
2024-01-25 19:27:43  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:27:43  Enc#2 SLOT 09    Time Out Error
2024-01-25 19:27:43  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:27:25  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:27:16  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:27:16  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:27:16  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:26:49  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:26:40  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:26:40  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:26:31  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:26:21  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:26:12  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:25:41  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:25:32  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:24:57  Enc#2 SLOT 10    Time Out Error
2024-01-25 19:24:47  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:24:21  Enc#2 SLOT 09    Time Out Error
2024-01-25 19:24:12  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:24:02  Enc#2 SLOT 12    Time Out Error
2024-01-25 19:23:44  Enc#2 SLOT 11    Time Out Error
2024-01-25 19:23:44  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:23:35  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:23:25  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:23:16  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:23:06  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:23:06  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:22:31  Enc#2 SLOT 12    Time Out Error
2024-01-25 19:21:47  Enc#2 SLOT 12    Time Out Error
2024-01-25 19:21:38  Enc#2 SLOT 01    Time Out Error
2024-01-25 19:21:29  Enc#2 SLOT 04    Time Out Error
2024-01-25 19:20:38  ARC-1880-VOL#000 Start Rebuilding
2024-01-25 19:20:28  Raid Set # 000   Rebuild RaidSet
2024-01-25 19:20:22  SW API Interface API Log In
2024-01-25 19:08:44  SW API Interface API Log In
2024-01-25 19:03:20  H/W MONITOR      Raid Powered On
2024-01-25 19:03:22  Enc#2 SES2Device Time Out Error
2024-01-25 19:02:26  Enc#2 SES2Device Time Out Error
2024-01-25 19:01:31  Enc#2 SES2Device Time Out Error
2024-01-25 19:00:36  Enc#2 SES2Device Time Out Error
2024-01-25 19:00:10  Enc#2 SLOT 11    Time Out Error
2024-01-25 18:59:58  Enc#2 SLOT 10    Time Out Error
2024-01-25 18:59:43  Enc#2 SLOT 09    Time Out Error
2024-01-25 18:59:37  Enc#2 SES2Device Time Out Error
2024-01-25 18:59:26  Enc#2 SLOT 04    Time Out Error
2024-01-25 18:59:14  Enc#2 SLOT 01    Time Out Error
2024-01-25 18:58:39  Enc#2 SES2Device Time Out Error
2024-01-25 18:57:44  Enc#2 SES2Device Time Out Error
2024-01-25 18:56:48  Enc#2 SES2Device Time Out Error
2024-01-25 18:55:54  Enc#2 SES2Device Time Out Error
2024-01-25 18:54:59  Enc#2 SES2Device Time Out Error
2024-01-25 18:54:04  Enc#2 SES2Device Time Out Error
2024-01-25 18:53:09  Enc#2 SES2Device Time Out Error
2024-01-25 18:52:14  Enc#2 SES2Device Time Out Error
2024-01-25 18:51:19  Enc#2 SES2Device Time Out Error
2024-01-25 18:50:24  Enc#2 SES2Device Time Out Error
2024-01-25 18:49:42  Enc#2 SES2Device Time Out Error
2024-01-25 18:49:29  Enc#2 SES2Device Time Out Error
2024-01-25 18:48:47  Enc#2 SES2Device Time Out Error
2024-01-25 18:48:34  Enc#2 SES2Device Time Out Error
2024-01-25 18:48:22  SW API Interface API Log In
2024-01-25 18:47:52  Enc#2 SES2Device Time Out Error
2024-01-25 18:47:39  Enc#2 SES2Device Time Out Error
2024-01-25 18:47:26  Enc#2 SLOT 12    Device Failed
2024-01-25 18:47:25  ARC-1880-VOL#000 Abort Rebuilding      000:25:39
2024-01-25 18:47:25  Raid Set # 000   RaidSet Degraded
2024-01-25 18:47:25  ARC-1880-VOL#000 Volume Degraded
2024-01-25 18:47:16  Enc#2 SLOT 12    Time Out Error
2024-01-25 18:47:06  Enc#2 SLOT 10    Time Out Error
2024-01-25 18:47:06  Enc#2 SLOT 09    Time Out Error
2024-01-25 18:46:56  Enc#2 SLOT 09    Time Out Error
2024-01-25 18:46:56  Enc#2 SLOT 01    Time Out Error
2024-01-25 18:46:46  Enc#2 SLOT 04    Time Out Error
2024-01-25 18:46:37  Enc#2 SLOT 01    Time Out Error
2024-01-25 18:46:10  Enc#2 SLOT 10    Time Out Error
2024-01-25 18:45:52  Enc#2 SLOT 09    Time Out Error
2024-01-25 18:45:52  Enc#2 SLOT 01    Time Out Error
2024-01-25 18:45:17  Enc#2 SLOT 10    Time Out Error
Please let me know if there is anything else I can grab for you.
Hello folks - still looking for guidance here. Anyone have any suggestions?
I'm not positive on the steps to recover the R6 array.
Code:
CLI> main
CMD     Description
ntp     NTP Functions.
exit    Exit CLI.
CLI> event info
Unfortunately, based upon your log you have additional serious issues going on with your array. You have entire array drive drops and time outs which with the failed drives have left your array in an unknown state. My first question is how important is the data on these arrays (if very important there are some things we can try.) In any case, before you do anything you need to make bit perfect copies of each of the array members (one by one, out of and back to its exact positions in the array.) Once that is done, you have a starting point where we can go back to baseline if one (or more) attempts do not work. Once that is done, we can try onlining the array and see if anything is there. We can force rewrite the signatures to the drives if you can successfully bring up one of the drives (I can't tell from the log if your drives failed due to actually drive failure, communications failure (bad cable) or some other reason, once you have the image copies (if you can make them) we can start to investigate each drive.
mwroobel, Thank you for getting back to me!
This array contains nothing that I couldn't live without; however it would be a terrible loss if I can't recover: Family photos, all my music digitized in FLAC, dumps of my previously designed webpages, etc.
It is worth my time to try and recover these files, but if in the end it's a no-go only the wife and I will be upset.
That said, if you're willing and able to provide instructions I'll be happy to follow them (word for word) in a hope that we'll be successful in the end. Just pm me your recommendation on a copy tool and I'll get rolling on creating images of the member disks.
Hi, long time Areca owner here, 12+ years, but first time poster.
Got a 1222-8 internal and two external boxes for backup, one on-site, one off-site.
My normally ultra reliable old Arc-1222-8 has started dropping offline. Starts up fine, works for a while, but then the Raid array 'R' drops out after ~30mins, (or goes to sleep not sure which, tho' its set to never sleep/ never spin down/ never low RPM) Do I have something set wrong to make it stay awake?
I feel it stays online if I keep using it, but if I pause to do other stuff, like email for awhile, it will drop offline, and be out till I reboot.
Anything I can do, or is it time for a new card?
I have an ARC 1223-8 sitting here, that I bought as a used spare, but... think I should upgrade to something more recent?
Anyone used the "classic" ARC-6120 battery backup unit for the 11xx/12xx/1680/1880 series with an 1882 card?
Do we have a pinout for the BBU cable?
From my understanding it won't work. PCB has to be v2.1 (model number ending in 21) and not the V1.3 from the other batteries.
