So I borrowed a friend's infrared camera to check the insulation on my house, and thought I'd do something [H]ard with it.
The laptop is an Asus G51JX-A1, in various Power4Gear modes. Ambient temp was 77F, it's not on a cooling pad, it's sitting directly on an MDF 1" thick cubicle table. Software was 3DMark2006 with standard settings.
Power4Gear set to Battery Saving, Idle at Windows 7 Desktop. Coretemp reported 113F on the highest core.
Power4Gear set to High Performance/Extreme Turbo, Idle at Windows 7 Desktop. Coretemp reported 123F on the highest core.
HP/Extreme Turbo with 3DMark06 on its second run, whichever test is the Antarctic Outpost. Coretemp reported 161F on the highest core.
Closeup of the keyboard while running 3DMark.
A shot of the left side where the exhaust fan aims. The wire is a USB cable for my G13 gamepad that I was using to monitor Coretemp with.
A shot of the power adapter while running under load. The strap across it is for my APC surge protector.
Underneath while running 3DMark.
With HP/Extreme Turbo, on a fresh install of Windows 7 Pro using the drivers that came on the CD in the box for everything, I scored 9624 on 3DMark2006. Nothing has been tweaked.
