I'm looking into getting a new motherboard, and I'm trying to decide between these two, the ASUS P5Q Pro Turbo, and the Gigabyte GA-EP45-UD3P.
From what I've been reading around, both are great 775 boards. Both are currently the same price after rebate as well. Which one would you all recommend? I don't need SLI/Crossfire, so that's not a factor in my decision. I do like the amount of USB ports on the UD3P, but I like that the P5Q Pro Turbo has eSATA, and I don't mind sacrificing 2 USB ports for it. The P5Q looks a little bit nicer in my opinion as well, color scheme wise. But that's really not that important if one functions better than the other.
Other than that, they both seem to be pretty similar, so I figured I would ask what you all though about each, and which one you would choose.
Thanks in advance for any help!
