I've suffered the double boot and various other problems with my Asus P8P67-Pro board, and some got relieved with the various BIOS updates provided by Asus on the forums here (greatly appreciated btw) but with 1253 Bios the system became nearly unuseable as it would either blackscreen or lock up in Windows not long after logging in. This was just trying to get it stable at stock speeds.
With the latest 1204 bios, I wanted to trouble shoot the two predominant problems I have been having with no overclocking:
1. Black screen/Flashing Cursor after BIOS screen
2. Random Windows 7 lock up usually minute or two after login
System specs are in sig, FYI.
I basically went through one at a time with each USB device, logged if it booted into Windows, and if I could run a session of Intel Burn Test, shut down, add new device, repeat.
BIOS settings were the following, rest were default:
OC Tuner: Manual
Bclk: 100
Turbo: Auto
Memory: 1600
Dram Voltage: 1.5
I also uninstalled AiSuite II and all Intel Drivers.
What I discovered is the following:
1. MX Revolution mouse, will cause lockups when using the latest Setpoint 6.2 drivers in Windows 7. Drivers uninstalled, lockups have ceased in Win7.
2. Belkin USB 7 port 2.0 Hub caused no keyboard to be detected by BIOS
3. UPS by Tripp-Lite causes Black Screen and flashing cursor
I had to do complete CMOS reset to get KB detected in BIOS with hub removed. So here is what did work via USB without issue:
1. Logitech G19 keyboard
2. Logitech G35 Headset
3. Microsoft LifeCam HD
4. Dell U2410 built-in card reader
5. Seagate FreeAgent 3TB USB3 (plugged in USB3 port)
6. Motorola Droid dock
My Logitech G13 is working, but Windows7 says there is no driver detected, but Logitech Gamepanel software detected it just fine. This may have always been a problem and I just never noticed before.
So for those who are still suffering Black-screen/flashing cursor, or random Windows 7 lock ups, try removing some of your extra USB devices and see if it helps. I have to say this board has it's peculiarities than any I have worked with before.
Here's hoping for another BIOS update that will clear up my USB issues.
If anyone has any similar occurences please add them. I think this might be another avenue that ASUS needs to explore in troubleshooting this board.
I will try loading up SetPoint 6.2 at some point over the weekend to see if it still happens, but want to get some time in on the PC while it is actually usable since I haven't been able to use it all week.
OC Tuner: Manual
Bclk: 100
Turbo: Auto
Memory: 1600
Dram Voltage: 1.5
