i was going to buy one of this but after seeing the price think i will buy old one congrats nvidia for gay pricing methodology oced gtx 285 is only 90 dolar cheaper than gtx 295 haha
not quite but the gtx295 is within about 10-15% or so from being twice as fast as the gtx280 sli setup. IMO the gtx285 needs to be way more than just 100 bucks cheaper than a gtx295 to make any sense.Does the 295 have twice the performance? u sure?
yes I know what he meantI think he meant it was near 280 SLI performance. Not twice as fast..
Notice it doesn't say a quad SLI 295, but the as in one 295.not quite but the gtx295 is within about 10-15% or so from being twice as fast as the gtx280 sli setup. IMO the gtx285 needs to be way more than just 100 bucks cheaper than a gtx295 to make any sense.
okay you are confusing me a bit. I posted the link to show that the gtx280 sli setup is only barely quicker than a single gtx295. so that means the new gtx285 looks overpriced compared to the gtx295 since it will essentially be just a little more than half the performance for only 100 bucks less.This is what my post referred to,
I was stating what he didn't take as obvious.
yeah if people stop for just a second and use some common sense they should realize that the gtx285 is ridiculously priced especially that model.Evga GTX 285 SSC - $429.99
MSI HD 4870x2 oc -$439.99
For some reason I just can't stop laughing, lmao.
c'mmon gtx 285 is as fast as 4870x2 its new it must beEvga GTX 285 SSC - $429.99
Multi-GPU options have way more problems across the board. Theres a reason so many people go back to using single GPU or SLI/Xfire. You get marginally more performance at the very top end out of the X2 and 295, but it makes just about 0 difference to actual gameplay, If you're a benchmarking fiend, then yea, go with the 295/X2, otherwise an SLI or xfire solution with single GPU cards will probably end up being better.
I think the term "ridiculously" is overstating it greatly. The GTX 285 pricing starts at $380. A quick check on Newegg shows the 4870 1GB cards are selling for $235-$275 and the 4870x2 sells for $429 on up. The performance of the 285 is right in the middle between these two cards in most games. Perhaps a better price would be $350 but $380 isn't that bad.yeah if people stop for just a second and use some common sense they should realize that the gtx285 is ridiculously priced especially that model.
yes it is ridiculous considering you can get the gtx295 for only 100 bucks and get nearly twice the performance. hell you can get a 4870 X2 for just 20 bucks more than a gtx285 so I still stand by what I said.I think the term "ridiculously" is overstating it greatly. The GTX 285 pricing starts at $380. A quick check on Newegg shows the 4870 1GB cards are selling for $235-$275 and the 4870x2 sells for $429 on up. The performance of the 285 is right in the middle between these two cards in most games. Perhaps a better price would be $350 but $380 isn't that bad.
cherry picking? so what... they are cards that are available and even the regular 4870X2 price is $449. the gtx285 at 380 bucks and above is NOT a very good deal. if you and others think it is then you are having trouble with basic math. I do agree with you on the dual card issues and I too would personally take a single card IF it was at a good price.You're cherry picking your pricing and including rebates to prove your point. Most 4870x2's are quite a bit more than $20 above a GTX 285. Plus dual GPU solutions are inherent to their own set of problems (microstuttering and extra heat come to mind).
well the gtx295 is NEARLY double(about 85%) the performance of a gtx280 so it would still be about 75-80% faster since the gtx285 is just clocked slightly faster than the gtx280.Umm....no, double performance is not accurate. Sorry, its just not. In some titles you may see an ~60% increase over the 280(stock) but we have no numbers as of yet on the 285, which at stock is clocked significantly higher than a stock 280.
EVGA 280 stock: 602/1,296/2,200M
EVGA 285 stock: 648/?/2484 - couldn't find the number on the shader clock
