You do know that the 120Hz TVs are not the same as a 120Hz monitor, right? The TVs use some "trickery" to achieve the 120Hz, they don't actually refresh that fast so you won't be able to run them at 120 off a computer.
Unfortunately, the MC/ME circuits also create artifacts that make film based content appear as if it was recorded as video rather than transferred from movie film.
I've owned my LN40B750 for a month now. It works really well as a PC monitor. First, you have to use HDMI input 1 and change its source name to PC/DVI. Once you do that (and calibrate it) you have a proper PC monitor with perfectly clear text. Its input lag might be a little high for gamers but for a combo HTPC, HDTV, and Blu-ray display, it's hard to beat.I think i found a really nice pick. The Samsung LN40B750 is promising.
Thanks for the input. Ye, the Samsung UN32B6000 i'm looking at is 3,000,000:1 Dynamic contrast ratio, LED backlight, 120hz. The Sony KDL-40XBR9 has 240hz and 100,000:1 Dynamic contrast but is fluorescent backlight.
I think i found a really nice pick. The Samsung LN40B750 is promising. CNET gave it superior reviews over even most LED LCD's and it's in a decent pricing bracket.
Quick Specs: 1080p, 150,000:1 Dynamic Contrast Ratio, Flourescent Backlight, 240hz/24p.
Interesting Reviewer Quote: "Uniformity: The screen of the LNB750 is more uniform across its surface than many LCDs we've tested, including the Samsung 7000, the Toshiba, and the Sony XBR9. It didn't suffer from overtly brighter corners as the 7000 and the XBR9 did, although in flat field test patterns we did notice the edges of the LNB750's screen appeared slightly brighter than the middle."
http://reviews.cnet.com/flat-panel-tvs/samsung-ln40b750/4505-6482_7-33490657.html?tag=mncol;lst
For a videophile you rely on cnet way too much. Go to avs.com and check out the forums for specific feedback and reviews on most of the major models or specific feedback for your particular models or brands you're researching.
UMMM and you think 120 hz monitors DONT use some sort of trickery???? LOL
The TC-P42G15 does appear interesting... Does the 600hz work similar to how LCD's 240hz works?
Most TV's claiming 120Hz do run the display at 120Hz, but they only accept 24Hz or 60Hz input. I haven't read a review of TV that accepts 120Hz input.
The main advantage for 120Hz sets is playing Blu Rays which are mostly 24fps (Hz). 24 *5 = 120, so you get no additional juddering watching movies on 120Hz set. On 60Hz set 24 fps gives uneven timing to frames, show one frame 3 times (48ms), the next 2 times (32ms).
Honestly I have no idea how a big a deal this 3:2 pulldown juddering is. I have a 60Hz TV and movies don't look any worse for juddering than they do in the Cinema.
IMO it's 24fps itself that sucks, its archaic, it cause jerky panning as is, we need to jump that to at least 48fps like some IMAX films. Much more lifelike, no jerky panning.
Hey guys i've recently decided on purchasing another HDTV and was looking around at all the different models and companies. I've come to the conclusion that i definately want a 120Hz+ HDTV. The models i've been looking at are the Sony Bravia 40XBR9 and the Samsung UN32B6000. If you guys have any recommendations it would be much appreciated. : D
Nielo, I agree with your replys so far, but if you're going to suggest the 40B550, the OP should also be told that Samsung's CMS color system menu is only available on the 650 series on up.After reading most your posts, the best choice for you personally is the Samsung 40B550.
I'm not sure of the UK models, but my B750 has 3 choices in the source name menu for HDMI1 for PC use - PC, PC/DVI, DVI. Of the three, only PC/DVI seems to bypass most of the processing that causes input lag. I haven't measured the lag, but to my eyes it's quite acceptable for anyone except hard core FPS gamers.The 650 has lag issue and the B550's color decoding is pretty good.
No
That refers to the subfield drive
For PC use, avoid PDP completely
why should you not use a PC on a plasma?
PS: There is a difference between 2:3 and even pull-down. A big difference
Okay, so in this case I'm thinking you would need an HDTV which takes 24Hz and upscales it with MCFI to a proper multiple.
What HDTV do you own that I assume does this correctly?
Yep, 120Hz.
Though, I do remember reading somewhere that some models scale from 24Hz -> 60Hz -> 120Hz which clearly is substandard. Christ, the HDTV market is unpleasant.
Yep, 120Hz.
Nielo TM said:Pull-down and MCFI are completely different
