Misadventure
- Nov 13, 2003
to display accurate temps etc. using an abit nf7s rev2
digiram said:I tried out mbm, and it displayed the my cpu temp @ 21 degrees celcius??? Stock hsf. Woot, but of course that isn't accurate. I wish that was true though.
fstroupe said:Have you checked the temp with another program? Just wondering if it is the mobo, instead of MBM, as it generally displays the temps that the mobo tells it to. I say generally, as some say it shows different info, but mine always shows the same info as the BIOS, as far as I can tell, anyway.
