http://svc.com/cs901bk.html
the back leaves room to be desired, not sure what kinda fan would fit but the removable mb tray is nice
penguin said:Holy CRAP batman!
That's the same basic design as the first case I ever owned (same mobo tray, anyway). If the rest of it's the same, then the toolless drives are some of the best you'll ever use - the rails are galvanized steel instead of flimsy plastic like most.
I dunno, if it's anything like the case I had (which really does appear to be its cousin), it's built like a tank. Heavy, but built like a friggin tank.inscape01 said:I've never had a problem with "flimsy" plastic rails. However I've had problems with flimsy cheap steel which this case appears to be.
