freakyhair
- Dec 22, 2002
Hi all,
just curious if anyone knows of a program that can convert a small, B&W 320x240 bitmap into hex. I have tried a few but they are usually limited by size, or convert only color bmps. in general, they don't quite do what i need.
if not, I have visual C++ (and am comfortable, but not great with C/C++), and would be willing to try to write a program, but don't really know where to start. I would also consider using visual basic C# if you think it would be worth my time. Are there easy ways to extract the data from bitmaps in visual c++?
I need this so I can display bitmaps i have created in illustrator on an LCD via an NXP ARM7 microcontroller. I have the mC side set up, I just need to figure out how to con ert the bitmaps easily!
Thanks!!!
Thanks!!!
