Even better. Way to fuck the consumer yet again, Newegg. Force them to buy a POS mobo. Mmmm hmmm. How's that bumrush?
More like screw over AMD. Nobody going to buy this when you have to buy a combo.
God, what the hell is wrong with AMD? While Intel is increasing the cache to 1x2mb per core and 2x2mb per core, AMD is decreasing it...
AMD's 65nm L2 cache looks to be slower
by Scott Wasson - 01:26 pm, December 21, 2006
After we published our first look at AMD's 65nm Athlon 64 X2 processors yesterday, some of you raised questions about funky performance numbers you'd seen from these 65nm CPUs at other sites. We focused on power consumption and overclocking in our initial look at the processors, assuming those would be the most interesting aspects of the die-shrunk parts, which were billed as otherwise offering performance identical to their 90nm predecessors. We should have known better, given the difference in L2 cache performance we noticed between 130nm and 90nm Athlon 64 processors during AMD's last die shrink.
I just ordered mine, anyone else get one? or see any OC reports?
Just to verify that the overclocked CPUs scaled well in terms of performance, here's a look at Cinebench rendering speed. Looks like the overclocked chips scale up more or less as expected. However, the Athlon 64 X2 can't match the Core 2 clock for clock, as the matchup of overclocked 5000+ versus Core 2 Extreme X6800 reminds us.
These chips are a little odd as overclockers, as early samples from a new fab process sometimes tend to be. They 5000+, for instance, would POST at 3120MHz and boot into Windows just fine, but when I ran Prime95, it wouldn't just throw a computational error when things got badit would up and reboot the whole system. There seemed to be little room between stability and "prone to fiery death."
http://techreport.com/reviews/2006q4/athlon-65nm/index.x?pg=4
Be warned!
These guys aren't Intel Fans or anything.
I'm certainly not, and I am shopping for a CPU and MB. I need a mATX case +CPU. I looked at Brisbane. It looks great, but not with the mATX choices offered. I bought an ABIT NF-M2, and I'm currently CPU shopping. I'll buy a CPU from somewhere else before I get saddled with crap on the single-most important part of my system. If your MB sucks and lacks features, guess what the rest of the system does.
well i have a tforce 939-6100 and i love it. i run gskill pc 4400 and a 3000+ @ 289x9 and i love it. ive read up on the 550 and it seems to do atleast 275. does any one know of a good 2 gig kit for the 550. i was looking at this
http://www.newegg.com/Product/Product.asp?item=N82E16820231087
any imput would be nice
Be warned!
stable 24/7 OC
Will you please tell me what memory you have and mobo with that! por favor
Wow, Dillusion great OC! For a ~$120 CPU that's kickass. I'll be satisfied if my 4200+ Windsor gets to 2.4, thrilled if it gets 2.6.
These Brisbane cores might turn out to be real winners.
EDIT: Dillusion, what cooling are you using and what case is this in. Thanks.
Silverstone TJ08, and AMD stock 4-heatpipe HSF
I really want to buy one tonight, i'll be saving a ton of money and it looks like they oc awesome.
Anyoen else have any input?
MB makers need to get off of their butts and make a solid, OC'able C2D MB for mATX. Until then, there isn't much choice for the budget enthusiast. I would have gone C2D in a heartbeat had I an Intel mATX MB to use that had decent OC options.
C2D at 3GHz is easy There are other cheap ATX boards though, why mATX? Anything else I say would sound like a flame.
