So my mobo bit the dust and instead of buying an old 775 board I figured I would get a new cpu as well. Budget is very limited (want to spend as little as possible) so I'm looking at the following options at the moment
$100 FX4100
$80 ASRock 970 Extreme3
$120 i3-2120
$87 ASRock Z68 PRO3 Gen3
or
$80 ($60ar) MSI H67A-G43
(prices from amazon so I don't have to pay tax/shipping)
People seem to recommend the i3 especially for gaming but it seems to me that after OCing, fx4100 would be comparable for gaming + have the 2 additional cores so I'm unsure what would be the better option. Going with intel would also probably give me a better cpu upgrade path for the future but would a mobo like the 2 I've listed be able to overclock say an ivy bridge i5 very well? If not I guess I'd be better off just getting a cheaper mATX board... On that note, if I decided to go AMD, would it be worth paying the extra $30 for the mobo I've listed instead of a $50 matx board (ie http://www.amazon.com/GIGABYTE-GeFo...ie=UTF8&qid=1340225090&sr=1-1&keywords=am3+)?
$100 FX4100
$120 i3-2120
or
