I've created a friend to the Tv class that gives Remote objects private access. Without success, though, I'm trying to create some friends to Remote so that objects of the Tv class, exclusively, can modify Remote private data without my having to resort to giving both classes (declaring all functions of both classes as friends) unnecessary access to each other's private data. In short, just some limited mutual classes.
Is it possible to extend Remote's declaration below Tv's, so that the compiler can find the Tv declaration? Or does constructing limited friend classes only work in one direction?
Thanks a bunch!
Code:
class Tv;
class Remote
private:
public:
[COLOR="Yellow"]friend void Tv::buzz(Remote & r);
friend void Tv::toggle(Remote & r); // compiler C2027 errors: use of undefined type 'Tv'[/COLOR]
class Tv
private:
public:
friend void Remote::set_chan(Tv & t, int c); // works
// Remote, Tv, and friend definitions
Thanks a bunch!
