Take for example this DDR3 2000mhz reaper 4gb kit is $109 before rebate.
http://www.newegg.com/Product/Produ...227571&cm_re=ddr3_2000-_-20-227-571-_-Product
Times that by 3, and you have 12 GB worth of 2000mhz ram for $330.
On the other hand the 6gb 'triple channel kit' costs $180 before rebate.
http://www.newegg.com/Product/Produ...15&cm_re=ddr3_2000_6gb-_-20-227-415-_-Product
Times that by 2, and you have 12 GB worth of 2000mhz ram for $360.
So you save $30 cash by buying 3 kits of 2x2gb rather than 2 kits of 3x2gb.
Is there a physical difference in the ram that wouldn't allow you to run the three 'dual channel kits' in tri-channel mode on a mobo that has 6 ram slots?
