I know the Mountain Mods will do dual 3x rads internal, but I can't recall if the TJ07 can do 3x rads or 2x rads. Maybe if you remove the drive cages, it'll do 3.
While it can fit a 3x120 radiator on each side panel, there won't be any space for the power supply, which would kill the deal for me
If you want to settle for a 2x120 and a 3x120, it will work
The top will take a 2x120 and the side will take a 3x120, and the other side can take a vertical PS.
