secure.boy
- Oct 22, 2007
I have problems...
the router worked very well, but we had to increased the speed from 128Kbps to 256Kbps (14 points are connected to this router by one serial interface through tellabs 2048bps, the other sites have cisco 2600 routers)
when i ping this router from 10.1.1.0/24 i get various time responses also lost packets
is the time to change the router?
for a week I need to remove the serial wic and to put the new FE, to replace from 2048bps to 10Mbps
Code:
cisco3640-hq#sh processes cpu
CPU utilization for five seconds: 99%/53%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 1068948 3018949 354 0.00% 0.00% 0.00% 0 Load Meter
2 2954692 1545913 1911 0.00% 0.01% 0.00% 0 PPP auth
3 22536828 2362921 9537 0.00% 0.09% 0.12% 0 Check heaps
4 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
5 4948 13264 373 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 4 267 14 0.00% 0.00% 0.00% 0 Serial Backgroun
8 58724 3009931 19 0.00% 0.00% 0.00% 0 ALARM_TRIGGER_SC
9 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
10 7744 503407 15 0.00% 0.00% 0.00% 0 Environmental mo
11 6706132 8040824 834 0.00% 0.05% 0.05% 0 ARP Input
12 3443404 16695761 206 0.00% 0.05% 0.02% 0 DDR Timers
13 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
14 20 2 10000 0.00% 0.00% 0.00% 0 Entity MIB API
15 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
16 0 34 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
17 3485800 9355071 372 0.16% 0.05% 0.02% 0 Net Background
18 1161672 1792038 648 0.00% 0.03% 0.00% 0 Logger
19 1275924 15047790 84 0.16% 0.03% 0.02% 0 TTY Background
20 1216124 15115542 80 0.00% 0.05% 0.03% 0 Per-Second Jobs
21 0 2 0 0.00% 0.00% 0.00% 0 Hawkeye Backgrou
22 0 1 0 0.00% 0.00% 0.00% 0 HDV background
23 0 2 0 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN
24 221680 1941270 114 0.00% 0.00% 0.00% 0 Net Input
25 5155112 3018949 1707 0.08% 0.07% 0.07% 0 Compute load avg
26 4798940 255034 18816 0.00% 0.02% 0.00% 0 Per-minute Jobs
27 0 1 0 0.00% 0.00% 0.00% 0 CES Line Conditi
28 1186096 59142839 20 0.00% 0.00% 0.00% 0 Framer backgroun
29 39859438003298223501 1208 44.12% 42.76% 42.69% 0 IP Input
30 688 230 2991 0.81% 0.17% 0.10% 130 Virtual Exec
31 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
32 0 2 0 0.00% 0.00% 0.00% 0 PASVC create VA
33 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
34 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
35 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper
36 414096 1912592 216 0.00% 0.00% 0.00% 0 PPP IP Add Route
37 7846444 2607775 3008 0.24% 0.13% 0.10% 0 IP Background
38 42272 253533 166 0.00% 0.00% 0.00% 0 Adj Manager
39 5732 11407 502 0.00% 0.00% 0.00% 0 TCP Timer
40 2956 3007 983 0.00% 0.00% 0.00% 0 TCP Protocols
41 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
42 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
43 0 1 0 0.00% 0.00% 0.00% 0 HTTP Timer
44 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
45 264576 348642 758 0.00% 0.00% 0.00% 0 DHCPD Receive
46 1380132 251594 5485 0.00% 0.08% 0.05% 0 IP Cache Ager
47 0 1 0 0.00% 0.00% 0.00% 0 COPS
48 4 1 4000 0.00% 0.00% 0.00% 0 PAD InCall
49 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
50 0 2 0 0.00% 0.00% 0.00% 0 ILMI Input
51 0 1 0 0.00% 0.00% 0.00% 0 SNMP Timers
52 0 2 0 0.00% 0.00% 0.00% 0 ILMI Request
53 0 2 0 0.00% 0.00% 0.00% 0 ILMI Response
54 0 1 0 0.00% 0.00% 0.00% 0 ILMI Timer Proce
55 28 2 14000 0.00% 0.00% 0.00% 0 ATM PVC Discover
56 0 2 0 0.00% 0.00% 0.00% 0 SSCOP Input
57 0 2 0 0.00% 0.00% 0.00% 0 SSCOP Output
58 6420 251727 25 0.00% 0.00% 0.00% 0 SSCOP Timer
59 0 2 0 0.00% 0.00% 0.00% 0 ATMSIG DRIVERAPI
60 0 1 0 0.00% 0.00% 0.00% 0 CES Client SVC R
61 0 1 0 0.00% 0.00% 0.00% 0 Crypto HW Proc
62 20 64 312 0.00% 0.00% 0.00% 0 ISDN Timer
63 400 294 1360 0.00% 0.00% 0.00% 131 Virtual Exec
64 4 2 2000 0.00% 0.00% 0.00% 0 CCVPM_HDSPRM
65 210336 15047796 13 0.00% 0.00% 0.00% 0 Net Serv Timer
66 0 1 0 0.00% 0.00% 0.00% 0 Crypto Support
67 0 2 0 0.00% 0.00% 0.00% 0 Router Autoconf
68 4 1 4000 0.00% 0.00% 0.00% 0 TSP
69 0 1 0 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
70 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP
71 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2
72 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE
73 4 2 2000 0.00% 0.00% 0.00% 0 Background Loade
74 0 1 0 0.00% 0.00% 0.00% 0 sssapp
75 24 44 545 0.00% 0.00% 0.00% 0 Crypto ACL
76 0 1 0 0.00% 0.00% 0.00% 0 Encrypt Proc
77 0 5 0 0.00% 0.00% 0.00% 0 Key Proc
78 1224896 15104587 81 0.08% 0.02% 0.00% 0 Crypto SM
79 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL
80 0 3 0 0.00% 0.00% 0.00% 0 Crypto CA
81 36848 1009079 36 0.00% 0.00% 0.00% 0 Crypto IKMP
82 40972 1678530 24 0.00% 0.00% 0.00% 0 IPSEC key engine
83 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
84 74444 475161 156 0.00% 0.00% 0.00% 0 ISDNMIB Backgrou
85 51504 650000 79 0.00% 0.00% 0.00% 0 CallMIB Backgrou
86 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
87 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
88 79236 1507336 52 0.00% 0.00% 0.00% 0 BUSYOUT SCAN
89 205184 14924384 13 0.00% 0.00% 0.00% 0 trunk conditioni
90 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni
91 72604412 2429125 29889 0.32% 0.32% 0.23% 0 ISDN
92 874636 9533070 91 0.00% 0.00% 0.00% 0 ISDN From Driver
93 0 2 0 0.00% 0.00% 0.00% 0 IP Flow Backgrou
94 0 2 0 0.00% 0.00% 0.00% 0 CCP manager
95 4329212 3683217 1175 0.00% 0.01% 0.00% 0 PPP manager
96 253120 15079444 16 0.00% 0.00% 0.00% 0 Multilink PPP
97 0 2 0 0.00% 0.00% 0.00% 0 Multilink PPP ou
98 0 2 0 0.00% 0.00% 0.00% 0 Multilink event
99 232 495 468 0.00% 0.00% 0.00% 0 IP SNMP
100 240 495 484 0.00% 0.00% 0.00% 0 PDU DISPATCHER
101 196 494 396 0.00% 0.00% 0.00% 0 SNMP ENGINE
102 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
103 399848 15176752 26 0.00% 0.00% 0.00% 0 NTP
104 6191400 14145151 437 0.00% 0.05% 0.05% 0 ISDN L2 Process
105 0 1 0 0.00% 0.00% 0.00% 0 ISDN L3 Timer Pr
106 1118640 9324425 119 0.00% 0.00% 0.00% 0 ISDN L2D SRQ Pro
108 3664 125868 29 0.00% 0.00% 0.00% 0 DHCPD Timer
109 115248 4276012 26 0.00% 0.00% 0.00% 0 DHCPD Database
cisco3640-hq#sh processes cpu history
11
9999999999999999999999999999999999999999999999999999999900
100 **********************************************************
90 **********************************************************
80 **********************************************************
70 **********************************************************
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
1 11
0999990099999999999999999999999999999998999999999877788888
0999990099999999999999899999998772218336049980242199326375
100 #########*####################*** * *#*
90 ##################################**##***#####*#* * **
80 #################################################*** ####*
70 ##########################################################
60 ##########################################################
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
1 1111111
0966677787789888900000009956555556654554455565555566565666767778888888
0525201115712979900000006081737501028216700845288477787253164224357702
100 ** *#######*
90 #* *****#######** ***
80 #* ********#########* *******
70 #* * *********###########* ** * * ************
60 ##******#**##############**** ** ** *** ** *************#######
50 ##***#####################*********************************###########
40 ###################################*******############################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
cisco3640-hq#sh ip cache flow
IP packet size distribution (1820M total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .015 .455 .136 .038 .043 .069 .030 .037 .075 .010 .016 .017 .016 .010
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .001 .006 .007 .010 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
16 active, 4080 inactive, 7161744 added
316004317 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 202 0.0 226 46 0.0 9.7 15.1
TCP-WWW 189 0.0 163 48 0.0 7.4 15.4
TCP-SMTP 3 0.0 105 48 0.0 2.1 15.4
TCP-other 162281 0.0 85 142 3.2 13.7 12.9
UDP-DNS 1182 0.0 232 59 0.0 9.0 15.5
UDP-NTP 640 0.0 62 96 0.0 0.1 15.4
UDP-other 2329 0.0 412 254 0.2 12.9 15.4
ICMP 15271 0.0 14 57 0.0 32.8 15.4
GRE 6979631 1.6 258 171 420.1 26.6 15.4
Total: 7161728 1.6 254 170 423.7 26.3 15.3
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Se0/0 XXX.YYY.28.250 Local XXX.YYY.3.14 2F 0000 0000 2128
Se0/0 XXX.YYY.29.250 Local XXX.YYY.3.14 2F 0000 0000 395
Se0/0 XXX.YYY.29.250 Local XXX.YYY.3.14 2F 0000 0000 57K
Se0/0 XXX.YYY.30.10 Local XXX.YYY.3.14 2F 0000 0000 60K
Se0/0 XXX.YYY.8.250 Local XXX.YYY.3.14 2F 0000 0000 32K
Se0/0 XXX.YYY.25.250 Local XXX.YYY.3.14 2F 0000 0000 40K
Se0/0 XXX.YYY.9.250 Local XXX.YYY.3.14 2F 0000 0000 82K
Se0/0 XXX.YYY.10.250 Local XXX.YYY.3.14 2F 0000 0000 2321
Se0/0 XXX.YYY.26.250 Local XXX.YYY.3.14 2F 0000 0000 28K
Se0/0 XXX.YYY.11.250 Local XXX.YYY.3.14 2F 0000 0000 7867
Se0/0 XXX.YYY.5.38 Local XXX.YYY.3.14 2F 0000 0000 33K
Se0/0 XXX.YYY.21.250 Local XXX.YYY.3.14 2F 0000 0000 31K
Se0/0 XXX.YYY.22.250 Local XXX.YYY.3.14 2F 0000 0000 3220
Se0/0 10.1.5.1 Local 10.1.1.12 2F 0000 0000 39K
Se0/0 XXX.YYY.7.250 Local XXX.YYY.3.14 2F 0000 0000 8933
Se0/0 10.14.1.3 Fa2/0 10.1.1.57 06 0F29 07E0 399
cisco3640-hq#
