I have a Corsair 620 HX powering my main rig. Specs are:
Core 2 Duo E6750
Gigabyte P35C-DS3R
EVGA 8800GTS 640
OCZ Plat. XTC 2x 1 gig
Creative x-fi Xtreme Music
with 3 WD 250gb, 2 Seagate 320gb, and 1 WD 500gb hard drives and a Samsung CD/DVD/Lightscribe burner, 6 120mm fans on a fan controller, and 12", 4" cold cathodes.
I thought the 620 watt Corsair would be able to power this, and up until recently it has. But, a few days ago, my system stopped POSTing, the fans would just spin up and my GPU fan would spin at max speed. After about 5 minutes of flipping switches and making sure everything was connected, I got it on and it worked perfectly. Next morning, same thing happened. Wouldn't POST initially, but after 5 or so minutes of fiddling it booted right up. This morning it happened again, and I decided to try unplugging some drives. With all my hard drives unplugged, it POSTed right away. Plugged em all back in, no POST. Unplugged 2 of them, POSTed.
Now, up until this point I had recently replaced my OCZ ram with Crucial Ballistix DDR2 800, rated at 2.2 volts. I took this ram out, put in my older OCZ Plat. XTC DDR2 800, which runs at 2.1 volts, plugged all my drives back in, and turned my PC on. POSTed right away, and it's been working fine.
[edit] I've had this Corsair 620 HX running for a bit over 1 year, bought it new last february.
Is my PSU going bad? Is my system just pushing the limits of my PSU? Or, could this be a different hardware problem? Any insight is appreciated.
Core 2 Duo E6750
Gigabyte P35C-DS3R
EVGA 8800GTS 640
