Hi everyone,
I was just wondering whether I will be CPU limited running 8800GTX with an Athlon X2 4800+ ? This is for a new system I am building. I am planning to get an LCD with 1920x1200 res, btw. Any ideas ?
At lower resolutions, sure, but the higher up you go the less the limitations.
At lower resolutions, sure, but the higher up you go the less the limitations. It's gonna take some frame hits but it shouldn't be a big deal.
at lower resolution you are more limited by the cpu ??? means a 15" monitor is limited by the cpu when using a 8800gts for example and same system config with huge monitor wont be limited an run better ???
No it wont run better. For a 15" screen the CPU will be the bottleneck. For a 24" or whatever screen then the GPU will be the bottleneck.
why that ???
Well it works like this...
Say you get:
200 fps @ 1024x768 (cpu limited)
200 fps @ 1280x1024 (shows the game is still cpu limited as more pixels are required, but the fps is the exact same or very close)
150 fps @ 1600x1200 (ah ha! Now we see we are pushing the gpu)
120 fps @ 1920x1200 (again, more pixels to render on screen... fps is lowering = gpu is taking a hit)
Now say you replaced your processor with a faster one, you might get something like:
250 fps @ 1024x768 / 1280x1024
175 fps @ 1600x1200
130 fps @ 1920x1200
You won't get better fps at higher resolutions, the bottleneck just changes from the cpu to the videocard and overall FPS will decrease.
Say you get:
175 fps @ 1600x1200
130 fps @ 1920x1200
What about, say, a GTX on a 3800+ X2 @ 1920x1080 res?
how much fps do you need anyways to run a game real smooth ??? Read that many games are limited in that way , you cant get more fps out of it even if your system specs would be good for more .Any way to calculate how many fps you get with certain setup ???
Because why spend a fortune on hardware when you cant even use half of its potential due to software limits ???
Awesome chart, but it could be extremely misleading to some considering over-clockability. It did make the AMD 6000+ almost look good though.
