How important is CPU PLL? I have it set at 1.88 right now, as the intel max is 1.89 and I am trying to find my max bclk.
Do I even need to overclock it? Can I just leave it at 1.8?
Also, I have my vcore and vtt at 1.4v. I am using a watercooling system with a large radiator (3x120mm fans). With a prime95 load, I run at around 78C. This is at 3.8 ghz.
I have been prime95 stable for around two hours at these settings.
Any of you guys think there is a chance I can push the cpu farther?
What prime95 load temperature should I consider my ceiling?
Thanks,
-Ian
Thanks,
-Ian
