The Abit IP35 Pro has eSATA and currently shipping boards will boot with a Q9450.
Why do you need a SLI or Crossfire motherboard?
right now i'm looking at an
evga 790i ultra sli
or
gigabyte GA-X48DQ6
or
Intel BOXDX48BT2
i read the evga has data corruption issues though
what about X38 boards, will they support the Q9450?
thanks all
i dont think it matters, i most likely wont be using more than one card. either one will do actually.
i have purchased the evga 790i SLI ultra because i might get a wild hair and MIGHT get another nvdia card but seeing at mainly a gaming board above everything else(and the data corruption issue) i might take it back and was looking at the gigabyte X48 board.
in the reviews i read it got last place in just about every catagory sometimes doubled in app performance. it did good with framerates though
i have the q9450 already but the knuckeheads from frys say those 3 are the only boards that will support that chip
just an fyi, no self respecting [H] user trusts what the knuckleheads at fry's say about anything when it comes to hardware.
Hopefully you realized before you bought the 790i that it takes DDR3 as your title was asking about DDR2. I've personally got the abit IP35 pro and it is running my X3350(Q9450 in Xeon clothing) just fine. WAY cheaper than any of the X48 or 790i options.
Well maybe one should consider Abit then. I have been a happy ASUS user for many many years.. .geez almost a decade I just realized. I will definitly be looking out for the reviews.. ok this was off topic..kind of.
Anyway Dunan, let us know what you settle for and how it works out, this is particularly interesting for me
What DDR2 are you planning on using, when you get rid of your DDR3 btw? Im already got my Corsair DHX2 CL4 800MHz, I just build a rig for a friend using this on the Q9450, set the timings manually and its running rock solid and pretty fast (he doesn´t like to OC).
i got 4GB of corsair XMS2 DDR2. switching the board and memory saved me $140 so i was naturally good with that
can you go into more detail on your issues with SATA cards?I wonder why eSATA is so scarce even on high end motherboards these days? Is it incredibly expensive for the manufacturer to implement? I have exactly the same problem (DDR2, Q9450, solid chipset need).. and don´t like to install extra IO cards because of potential stability issues I´ve experienced with SATA cards. Thanks for posting this Dunan, and for the info BUFF and Wolf2009.
Maybe one should hold out for a P45 though... I hope they pull themselves together and realize that eSATA is crucial on enthusiast motherboards.
Hmmm. The item I linked isn't a card, just a bracket - kinda like an extension cord for the SATA ports already on the motherboard.It would BSOD my XP 32. Tried various PCI slots and a few drivers. I believe it was a Promise SATA300 TX2... But thats from memory, and it´s some time ago. It really annoyed me, thought it was an IRQ thing at first, but it wasn´t.
Maybe the card was bad, in any case I just janked it, and stayed away from SATA II disks.. have one lying here waiting for my next motherboard. Its been a good and unbearably long while since I upgraded. Running an ASUS A8V Deluxe using the FastTrack 378 controller, maybe that was the conflict...?
Perhaps I should relocate it tomorrow and take a new look at this problem. But I am upgrading in August, when I go to the US
