WickedWeasel
- Jul 13, 2004
I took off the Intel E2160 to change the thermal paste. I noticed the original installation from the store had white paste everywhere, overflowing beyond the chip, and eventually I had to remove the chip to clean some paste from the sides. There was also a tiny bit on the motherboard contacts, so I used q-tips to try to clean it off, but the q-tips gets caught so I used a towel to very gently wipe them (no alcohol). The outer contacts (just the edge) on the chip were cleaned by using 70% rubbing alcohol. let it dry for a few minutes. Applied AS5 and put everything back. Tried to restart it, and it gets stuck in an infinite boot loop.
1. System has never been in an infinite boot loop before today, not even once. when i was experimenting with overclocking, a failed overclock would just reboot twice and everything would reset and boot up without problems.
2. my overclock was modest at 9x300fsb, 2.7ghz, vcore at around 1.3250. today's settings were the stable settings.
3. tested the computer just before taking out the motherboard and had no problems.
4. when i remounted the Heatsink, i dropped a few washers onto the motherboard
now, upon a reboot, there is NO speaker beep. no beeps at all. the computer just goes into an infinite reboot loop. I let it run for a few minutes before shutting it down. Reset the cmos by placing a jumper for 1 minute (did not remove the battery).
left in 1 stick of RAM, unplugged the DVD, checked all connections.
still in infinite reboot mode, and all fans spin up when trying to boot.
Is the CPU ok? will cleaning the cpu help, or is the motheboard fried? what is the best way to clean the 775 contacts on the motherboard? Did dropping the washers fry the motherboard? I did not see any sparks, and the motherboard was sitting on the table for 2 hours before I started to bolt the HS on.
using a thermalright 775 bolt thru kit.
