I found a decent thread on this - but it was a good four years old ...
Anyways... I want to try this.
-Direct to IHS
-Direct to Core [removed IHS Ivy Bridge CPU]
I have access to professional 3D design software and a high end 3D printer to make a block. Hell I could even print the hose connection barbs into the block. I'll just use an o-ring to seal around the core or the on the IHS surface. I don't see much of an issue keeping enough clamping force on the block to the CPU to maintain an o-ring seal.
-Is it worth it for Ivy, though? I have read that Ivy's not much of an overclocker. My sandy does 4.6 at quite low voltage on air.
-Has anyone done it direct to core on IVY and determined it will NOT work? (i.e., shorted circuitry, etc) I could always lay down some of my own epoxy around the core if needed.
-Anyone have some good #'s for water cooled Ivy's so we can make a comparsion to block cooled specimens?
I currently have a p8z68-v LX motherboard with a i5-2500K @ 4.6ghz on air. This mobo was about $20 after discount so I suppose ill need a better board. :-P
-Direct to IHS
