YARDofSTUF
- Jun 19, 2001
So whats best, what does more?
I think I remember reading that O&O Defrags the pagefile, not sure.
QFT....if you decide to buy one, I concur: PerfectDisk....KoolDrew said:All of the popular commercial ones do. Not that it is necessary though and even if you wanted to defrag the pagefile there are free utilities available that will do it. If you really want to buy a defragger get PerfectDisk. The last time I tried Diskeeper I noticed it does a terrible job at consolidating free space. Whether or not this has changed in recent versions, I don't know.
However, considering fragmentation isn't a big problem nowadays, I wouldn't pay money for one. Just stick with the built-in defragger.
1st time i tried it it gave me BSOD too. never used it again. using diskepper now. no problems yet.TheGamerZ said:For some reason O&O would always cause a BSOD on my comp.
No, unfortunately, I don't. I really should put it on a test machine of mine and give it a whirl. I've never heard anyone complain about it, so it definitely deserves a chance.ChingChang said:djnes, do you have any experience with Perfect Disk and how it would compare to the others? any stability issues?
Ice Czar said:O&O Defrag Pro
Invaluable tool for optimizing, wouldnt want to be without it
I have it intgrated into the MMC and from the commandline as well
running version 4
saturnine2 said:It gives you more options, lets you defrag based on date, filename, etc.
t. shuffle said:I have never understood how either of those options would be valuable.
Complete Name > Using this convention it is possible for you to create directories that will comntain Program Groups closer to the OD (Outer Diameter) of the HDD platter where both the sustained transfer rate and the latency are better, alternately, aps or data that doesnt require a high sustained transfer or that are infrequently accessed can be placed in a directory closer to the ID of the platter (or partition) basically it extends the partition strategy into a single partition, my Adobe and AutoCAD directories being in a much better position than Video Directory (media doesnt require much if its read only)
Complete Date or Access > are primarilly for Database server use, though if you give some thought to it....
say you mount an NTFS Volume as a folder (we'll make it a logical partition\drive in the backend of the HDD in an extended partition) this partition simply holds email files or docs, none of them very big, so even with the lower density in the ID of the disk, the files are also smaller and the latency thus offset, organizing these by date is likely adventageous since your more likely to need to access those than older "storage", thus those files will be closer to the front of the partition, so that when accessed the armeture and head will have less distance to traverse and their position farther out from the ID will have better density and thus lower latency
(caveat, by placing those small and frequently access files as a mounted drive located at the back of the HDD, the arm would need to traverse far outside its "normal" OS partition with considerable ncreased latency, your best access is within any given partition, one of the reasons indexing can have a negative impact on HDD performance, so downloading and writing email as you recieve it by leaving your client open as opposed to checking your email a few times a day can act very similar to indexing, would have little impact for gebneral use, but if your Photoshopin or working on some other disk intensive access, it can be a performance loss)
to understand disk access optimizing its important to understand disks first
Id highly recommend the As the Hard Disc Spins series @ Lost Circuits and Partitioning Strategies @ Radified
