Well, I cant really seem to get either CPU-Z, CoreTemp, or TAT to work in Vista x64 (I saw the threads on how to do it), however I'm using HWMONITOR...
I'm using an Abit IP35-Pro, 4gb of OCZ SLI edition, E8400 and eVGA 8800 GTS g92
When I first booted up the chip was running at a speed of 1800 mhz, using a 9x multiplier, aren't these supposed to be 9.5? FSB at 200.
I set it manually to 3.04 ghz (333x9)
The temp report in uGuru or what not was showing some really low numbers (talking below 10)
Right now, only thing I found to report temps was HWMONITOR, it's showing these under abit UGuru tab:
Volts CPU Core 1.12 V
CPU Temp 20 deg C (this, during Orthos...) was at like 5 degrees earlier.
After that, under the Intel Core 2 Duo E8400 tab I see:
Core 0 63 deg
Core 1 63 deg
I'm using a Tuniq Tower 120 w/ stock fan, don't have my tube of AS5 right now so just used the Tuniq TX-1 (edit) grease temporarily. Never really used it, but applied it by spreading it with a little plastic bag really thin, applying a tad more (I mean a tad) and spreading that with an exacto knife (no razer blades).
I'm contemplating just installing XP to bench this instead of this Vista x64 crap.
Anyone got any ideas? Should I update my BIOS?
If the second monitor is right its saying I'm idling at 50 degrees in a cold room at stock, which is worse than I used to do with a Tuniq and E6600 running 3.0 under load in a hot room.
Core 0 63 deg
Core 1 63 deg
