Did this happen to anyone else? It's supposed to have 2, even shows it on the box.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
Keep in mind one port is covered by a thin aluminum protector (same thing with several USB ports and eSATA), if you wiggle it back and forth it'll come out. Generally speaking, it's better to leave the protector there unless you need two LAN plugs to keep dust and EM interference out.
That "protector" is on the I/O plate that is placed on the back of the case.
It is a seperate piece and would not be on the board as it comes out of the retail box.
The guy hasn't even installed the board yet.
I would guess when your MB was boxed, the guy put an LE in a normal X58 SLI box.
Shit happens, bu it sucks when you are the one it happens to!
I'm sure EVGA will make it right. Question is, do you really need two ethernet ports?
If you don't maybe EVGA can just refund you some dough.
Good luck.
Impossible it's the LE version. The LE version is totally black just to start with. I emailed them, they want me to take it out and take a picture of it. Oh well
Snap a pic and post it here.
Also, you can PM me your SN/PN if you'd like and i can see what i can do for you as well.
They asked me for the part and serial numbers on the motherboard and now that I look at them they are NOT the same numbers as the ones on the box!
So what's with this...
You just get an incorrect box?
...just like all brand new mobos of that type....
you couldn't tell just by looking in the case?
Sigh..............................
