If the value in B2 is "1" and not 1 (without quotes), then, yes, that will work.=IF(AND(A2="Yes",B2="1"),"Yes","No")
Look into the SEARCH and FIND functions, and read up on the error handling if a substring match is not found.ok what if I wanted to say
If column A2 contains "yes" (it could contains yes123 or yes 234 etc) and column B2 contains 1 then Yes else No
I can't use wild cards in an If statement.
