I have an upgrade picked out for my PC, and this is kind of a big thing since its the first time basically building my own. Its a mobo/cpu/hsf/ram/gpu upgrade. Just want to make sure its a good build, everything is compatible with everything. I plan to use it for gaming, and basic use. I do plan on OCing.
There are 2 things i have a question about. First, my mobo i picked out has a Memory Standard of DDR2 1066, and the RAM i picked out is DDR2 800, will that work out? The other question i have is, is the HSF i have now worth it, or should i just go with the Arctic Cooling Freezer 7 Pro? The reason I went with the ZEROtherm Nirvana is because of the looks, but its not that big of deal. Any other HSF suggestions are welcome.
Mobo - GIGABYTE GA-P31-S3G
CPU - Intel Pentium E2180
HSF - ZEROtherm Nirvana or ARCTIC COOLING Freezer 7 Pro
GPU - EVGA 8800GS
RAM - mushkin 2GB
I'll also be buying 2 120mm fans and 1 IDE cable. I'll be reusing a DVD/CD Drive, an Antec True Power 2.0 PSU, the case and 1 120mm fan.
My budget is 380-400 no more, and i do look to upgrade, probably for sometime during summer.
Any suggestions are welcome.
GPU - EVGA 8800GS
RAM - mushkin 2GB
