Feedback: Heat 40-0-0 and eBay 90-0
All prices are shipped in CUS. Let me know if you have any questions, if you buy a bunch of the memory I'll cut you a nice deal.
Full Systems:
Hard Drives:
Laptop Memory:
Misc:
Wanted:
Full Systems:
Inspiron 6000 ($75):
The only issue is that the hinges are a little weak and the screen wobbles a little if moved.
- Pentium M 715 1.5ghz
- 1GB RAM
- 120GB Hard Drive
- 15" WXGA
- Intel GMA 900 integrated graphics
- DVD-ROM Drive
- Battery included, but doesn't charge at all
Vostro 1500 ($200):
- Core 2 Duo T5450 1.66ghz
- 4GB DDR2
- 120GB Hard Drive
- 15.4" WXGA
- NVIDIA GeForce 8600M GT GPU
- DVD +/- RW double layer drive
- Minimal battery life (15-30 minutes)
- OEM AC Adapter
Vostro 1400 ($200):
- Core 2 Duo T7250 2.0ghz
- 2GB DDR2
- 160GB 5400RPM HD
- 14.1" WXGA LCD
- Intel 965 Express Chipset Integrated Graphics
- Integrated web cam and mic
- OEM AC Adapter
Hard Drives:
Seagate Momentus Thin 250GB ($70):
7mm 7200RPM drives are tough to find if you have a computer that requires one. Drive runs great, just decided to jump to an SSD.
- 7mm SATA 2.5" Mobile Drive
- 7200RPM
- 250GB
Laptop Memory:
1GB Elpida DDR3 PC3-8500 ($10):
- 204-pin SODIMM
- DDR3 1066mhz
(5) Samsung or Hynix 512MB DDR2 PC2-4200 ($5 each, $4 if buying 2 or more):
- 204-pin SODIMM
- DDR2 667mhz
(2) Samsung 256MB DDR2 PC2-3200 ($8):
- 204-pin SODIMM
- DDR2 333mhz
(2) Hynix 128MB DDR PC-2100 ($5):
- 204-pin SODIMM
- DDR 266mhz
Misc:
Replacement Receiver for Logitech MX1100 ($13):
Wanted:
Logitech G700 Mouse:
