killernoodle
- Aug 4, 2002
Up for sale is a Gateway model 205 projector. Here are the specs:
http://www.projectorcentral.com/Gateway-Model_205.htm
I'm selling this projector with a brand new, never used spare lamp. Spare lamps cost around $300 ish new, so its a good idea to buy a projector and have a spare lamp available. The bulb that is in there has like 280 hours on it
Anyways, the projector will come with the power cord, the carrying case, the remote with a laser pointer and mouse built in, a VGA cable, a component video cable (home made, works great), a S-video cable, and a composite cable. It is in perfect shape, no scratches on the lenses or on the case, it is still very shiny! This projector is also VERY SMALL! Just look at the dimensions. It weighs less than 4 pounds but is still built very sturdy.
So far, I have had no problems with the projector. It has worked fantastically for me. It warms up in less than a minute, the screen is very clear and bright with good contrast. Movies and Xbox on it are phenominal, especially with a good screen. It is also very easy to use, just plug it in, turn it on, and it automatically selects the input and changes resolution. It scales high resolution nicely too, you wouldnt know it is only 800x600 because it looks much better than that. Colors are crisp and DLP technology means that there is no image ghosting what-so-ever. So gaming is definitely awesome on it. Overall, I have been very satisfied with this projector.
I'll take $500 for it shipped or any reasonable offer. Pictures will be emailed on request.
AIM: SwissPatriotRG
Email: (preferred) [email protected] ([email protected])
Heat: killernoodle
Code:
MSRP (USD) : $1,099
Brightness (Lumens) : 1000 ANSI
Contrast: 1100:1
Weight: 3.8 lbs.
Size (inches) (HxWxD) : 2.2 x 9.8 x 6.7
Throw Dist (feet) : 4.9 - 26.3
Image Size (inches) : 25.7 - 178.1
Lens Focus: Manual
Zoom: Manual, 1.30:1
Digital Zoom: Yes
Keystone Correction: Digital
Compatibility:
HDTV: 1035i, 1080i, 720p
EDTV/480p: Yes
SDTV/480i: Yes
Component Video: Yes
Video: Yes
Digital Input: No
Personal Computers: Yes
Lamp:
Type: 150W NSH
Life: 2000 hours
Display:
Type:0.6" DLP (1)
Native: 800x600 Pixels
Maximum: 1280x1024 Pixels
Aspect Ratio: 4:3 (SVGA)
Performance:
H-Sync Range: 31.5 - 80.0kHz
V-Sync Range: 43 - 100Hz
Max Power: 250W
Voltage: 100V - 240V
FCC Class: B
First Ship: May 2003
Last Ship: Jan 2005
AIM: SwissPatriotRG
Heat: killernoodle
