knothead34
- Apr 4, 2005
all im telling everyone is what the bb salesmen told me and what ive experienced in my state. he also gave the impression they are selling fast. forgot to mention it above.
Well, I bought one yesterday. I was wondering how I get my free game.
Ok swapped out for a T9300 I must say a immeadiate improvment.
stock 3d mark 06 8600
with T9300
3d mark 06 9700
also added 2 7200 rpm seagates for raid 0
picked up the Gskill 4-4-4-12 2 x 2gb and memory bandwidth went from 4000 to 4500 chipset picked up timings just fine.
must say the upgrade really makes a difference especially coupled with the 7200's in raid0
vendor was great on the cpu no issues (grassroots)
very fast.
with T9300
3d mark 06 9700
very fast.
Alright, but I bought it on Sunday. I had them do a Rain Check for me because I was away on business when they had it. I got mine for $1199.99 + Tax. I then added 4GB of Geil RAM and T7500 Processor. This thing screams. I was trying to figure if I should use the 250GB 5400 RPM or my 120GB 7200RPM in it. What do you guys think?
screw that buy 2 7200's raid them and then get a $5 external enclosure for the 250 and use it for storage. that is what i did and you think is screams now just wait till you pump up the file system to match the machine.
can't wait for SSD's to come down.
hehe.....was on craigslist when I came across this
http://stlouis.craigslist.org/sys/590552798.html
check out the spec sheet......little different (screen resolution and gpu says GTX)
and that price...OMG
Methinks a scam!
Where can I nab up one of those T9300's or an equivalent to put in my P-6831?
I am going to pick one of these up next week. Intially i planed on leaving it with the components it comes with and after it's year warrenty runs out i figured i could score some cheap upgrade components 200GB HD 7200RPM, 9300CPU, etc.
This will be my first laptop so i have a couple questions.
Is the extended warrenty worthwhile or is it a scam?
How long is the battery life? I was thinking of taking this to school to take notes in class
Are there any good backpacks out there that will fit this laptop well?
And lastly for those that have bought this awhile ago, how are you liking it?
On Laptop Video 2 Go's Forum, 169.44 didn't work for me either.where did you find 169.28 , the best I can find is 169.09 . The driver that came with it keep loading mulitple display performance mode on clean boots. I went around it by using the program settings for COD4 and loading it with single performance mode. Made the world of diff. Not choppy at 1440 any more. Hopefully these 169.09 I am downloading will fix that and add a little performance. Well no luck installing either ones you guys listed. Would not install. I still am using the ones that came with it. If anybod finds any better that has installed for them, please link them for me. Thanks
