Seems Nikon has discontinued most of their macro equipment. I guess they feel that since the macro lenses do 1x on their own that should be enough.
It isn't.
So, off to eBay I've been. Until the last few months, I've never had any use for eBay at all but when it comes to discontinued equipment that seems to be the place to look.
So here is how we get really close:
That is a PB-6 bellows. It gives me up to 200mm of extension. It is sitting on a pair of PB-6D spacers (to allow the D2X to fit). The D2 connects to it via a PK-12 extension tube. The lens is a manual focus 35mm f/3.5. It is inverted using a BR-2A reversing ring and has a BR-3 coupling ring attached to it both to protect the lens mount and to allow 55mm filters to be attached.
Also from eBay, I found a complete set of PK extension tubes, a PN-11 extension tube and a Nikon 6T close-up filter. Although obviously I won't get the capability of the bellows, they will give me the ability to get a bit more magnification in the feild.
Of course one cannot show off new photographic toys without presenting an example so I set up quickly with some salt. This is about 7x:
It isn't.
