I just bought my GTX 285 SC and I haven't overclocked it.
I upgraded from an 8800 GTS 512 so I don't know normal gt200 temps. I've tried searching but I can't find fan profiles for Rivatuner so I have it set up for:
temp speed
40 40%
50 60%
60 80%
70 100%
The problem is that when I play Dawn of War 2 my temps shoots up to 60+ and then eventually ends up in high 70s range.
But the strange thing is that around mid60s in DoW the card artifacts like crazy. I green dots and white flashes all over the screen. The whole screen will sometimes flash black textures.
I don't get as high temps in Crysis. I get high 60's low 70's if I keep the fan from going 100%. Even then, I don't get artifacts like that except when I really push I get some tiny black dots flashing at the highest temps.
So my first question is where I should be setting my fan speeds if those aren't adequate?
Why do I get artifacts in the 60 degree range?
Have I damaged my card or received a defective one that needs to be RMAd?
Or could this be due to a lack of power? It takes two 6pin plugs but I used the same main line with two 6pin plugs on it. Does it make a difference to use two separate wires?
temp speed
40 40%
50 60%
60 80%
70 100%
