i just upgraded the 2x2GB in my GA-H67n-USB3 to a 2x4GB set i had lying around. when i started it, it just power cycled endlessly so i replaced the 2x2GB set i had and it works fine still. then to trouble shoot i found that it works with a 4GB dimm in either slot, a 2GB dimm in either slot, or 2x2GB dimms. any idea how this could be? could it have to do with voltages or something? the 4GB set is this one, and the 8GB set is this one. im just running on one stick right now since i need to find an extra 64 bit key before i can use the extra 4GB anyway, but im very puzzled as to why it will work with a 4GB dimm in either slot, but not with one in both. any help would be appreciated, thanks!
