Hey!
My friend here wants to make the display and sound clone for the kitchen and the living room. We told them to get a Radeon 6670 and hook it up using a DVI-HDMI adapter and using the other regular HDMI connector and they would be able to clone the displays and the sound. Apparently the sound will only work over the HDMI connection and it won't go through the DVI-HDMI. Does the sound go through the DVI connector at all, or does sound go through the mini displayport connector as well? Trying to find a cheaper solution than getting an HDMI distribution amplifier.
Basically what do you guys suggest doing to get this working, just need sound and video in both rooms using 1 Radeon 6670, the motherboard has optical sound as well but that should be used only if HDMI can't.
here's a high-res picture of an Asus 6670
