terrabyte89
- Nov 6, 2004
Hi everyone! Hoping I might be able to get some help from the knowledge vault that is horde .
I have a 4p opteron build here that I bought a little while ago second hand. Running a supermicro H8QGi+-f board and 4 opteron 6170 chips. The board had one cpu socket with a snapped pin (memory channel pin). I tried repairing it but didn't really get anywhere.
Anywho, I'm finding the whole system is powering down after around 18 hours running full load. (boinc). Sometimes it'll last 24 hours, other times it will do it in less than 12. So instincitevely I pulled the cpu from the borked socket but still did it running 3p :/. Knocked it down to a 2P. and it took nearly 48 hours but it still powered down.
Checked the bios, there's no alarms set or anything like that. IPMI is disabled. She passes memtest on all sticks of ram, windows logs show nothing except an unexpected shut down when I power it back on. Board logs are also empty. I'm just about out of ideas!
I've tried a 1200w silerstone Strider and also a 1200w Antec quattro psu, both of which should easily power this. Was running the OCNG5 bios but have since flashed back to factory and it did it on both.
I can't really check the temps unfortunately because all it shows is Low/Medium/high instead of the actual temp . The only temperature value I can see is the system temp which hovers around 30c. This I also find odd as my other H8QGI showed actual temperature values!
I've just booted up linux with boinc to see if it does it in that too (Currently have been running server 2008R2).
Any help with this is much appreciated!! Thanks
