SixFootDuo
- Oct 5, 2004
HOT: Corsair Vengeance RGB Pro 32GB ( 4 x 8 ) DDR4 3000mhz $218 Newegg
A friendly reminder - If you enjoy and use HardOCP Hotdeals forums, please consider using a HardOCP affiliate link for your purchase and or consider a small monthly Patreon donation. This helps HardOCP to continue to bring us great content.
https://www.newegg.com/Product/Prod...LC-_-na-_-na-_-na&Item=N82E16820236426&cm_sp=
NOTE: This sale is for 6 days only. Also, it's very possible these could sell out. If you have the cash and want them then you probably shouldn't drag your feet.
Above average score from buyers. Again, if you have AMD, owners are reporting that they are having trouble getting the rated 3000mhz speeds. This is with me going through both the Newegg and Amazon reviews so I can confirm this issue is often discussed. With that said, an Intel user reported overclocking results to 3600MHz with 18-22-22-39 timings at 1.42v 2T command rate.
Note: Many owners consider this new Vengeance RGB Pro memory to have the best RGB effects out there. Of course this is largely comes down to "whatever floats your boat."
Here is a random video of the RGB effects.
