HP LP2465 (widescreen) has a 24 inch 6 ms (g2g) S-PVA (Samsung LTM240M2) panel.
Manufacturer Hewlett-Packard
Manufacturer Part # EF224A8#ABA
Cost Central Item # K37014
Product Description Smart Buy 24in Lcd 1920x1200 60hz Lp2465 Carbonite/silver 2 Dvi
Device Type Flat panel display / TFT active matrix
Color ( the image may represent the product of a different color )
Approximate Dimensions (WxDxH) 19.7 in x 9.1 in x 21.8 in
Approximate Weight 23.6 lbs
Localization English / United States
Diagonal Size 24"
Dot Pitch / Pixel Pitch 0.27 mm
Max Resolution 1920 x 1200 / 60 Hz
Color Support 24-bit (16.7 million colors)
Response Time 8 ms
Image Brightness 500 cd/m2
Image Contrast Ratio 1000:1
Interface DVI
Compliant Standards Plug and Play, TCO '03, CE, MPR II, CSA, UL, TUV, VCCI, BSMI, PC 99, EPA Energy Star, GS, ISO 13406-2, NOM, CCC, TUV Ergo, MIC, FCC
Power AC 120/230 V ( 50/60 Hz )
Power Consumption Operational 75 Watt
Manufacturer Warranty 3 years warranty
$712US after rebate + free shipping
Can you post some pics if you are the owner
or you had more review .
Thanks
Diagonal Size 24"
Response Time 8 ms
Interface DVI
Thanks
