houkouonchi
RIP
- Sep 14, 2008
Anyone know a specific model of motherboard (hopefully on the cheap) that can power an HP SAS expander with no CPU/memory installed?
Does it have to be a motherboard? If not you may want to take a look into this thread here: http://hardforum.com/showthread.php?t=1519806
Here is a solution. It is half a motherboard, just the power connection. You screw it in your jbod chassi. Read review on this
http://www.orbitmicro.com/global/pe-2sd1-r10-p-9375.html
Well the dual 771 socket supermicro board these coraid disk chasis came with actuall work for powering the card with no CPU/ram.
Unfortunately only one of the three 15 chasis actually have the newer motherboard with PCI-E slots in it so maybe I can bum another one off my co worker who got more than I did.
I already have that. No you don't just screw it into your jbod chassis you have to dremel or some how otherwise remove the huge PCI-E looking thing on the bottom of it. See:
http://www.orbitmicro.com/global/imagemagic.php?img=../i/9375-3.jpg&w=700&h=650&page=popup
Not a simple mod.
Aren't you putting this in a Norco case? Norco standoffs are as tall card slots so you should need to remove the card slot while still being able to mount in location/orientation so you Expander can still use one of the card slots on the case. Also nothing says you have mount it this way, you us larger standoffs, mount it in the middle of the case, rotate it 90, etc.
No I am not (supermicro case); however, I did realize that I have some flexible risers and some other risers that I might be able to jerry rig to mount the card correctly.. doh why didn't I think of that. Gonna go try that out now!
The stand-offs on the original Norco 4020 used to be tall enough not to need to chop the plastic bracket on the bottom of the power board, but any newer Norco cases and you'd have to chop it unless you found a creative way to raise it up. Removing the plastic bracket takes 30 sec with a cut-off disc on a dremel tool, I've done several of these boards and its pretty low risk to damaging the board unless you're michael j. fox
The power board is definitely a pain because another problem is the mounting holes don't line up perfectly to ATX dimensions. On the last power board I installed in a Norco 4224 I had to tap a couple screw holes at the bottom of the case to place the stand-offs.
