(cf)Eclipse
Freelance Overclocker
- Feb 18, 2003
so you guys probably know about how intel can do 3-2-2 and AM2 can't because it doesn't support trcd 2 or trp 2?
well, straight from an AMD tech document, AM2 supports CAS2
1. Determine all CAS latencies supported by each installed DIMM, defined in SPD byte 18. One bit
corresponds to each supported CAS latency. SPD byte 18 specifies CAS latencies with which
devices on the DIMM can reliably operate. BIOS should not assume that a device can operate
with either slower or faster CAS latency than those specified by the SPD. The DRAM controller
is designed to support CAS latencies 2, 3,4, 5 and 6.
