Dec 31, 2004 #1 N Noah Limp Gawd Joined Feb 15, 2004 Messages 273 What parts should I be buying? I MUST stay within the price limit I mentioned ($450). Any suggestions?
Dec 31, 2004 #2 S ScYcS 2[H]4U Joined Dec 11, 2004 Messages 3,960 Qty Product Description Unit Price Extended Price Fans, Heatsinks (Case, CPU, Chipset) Arctic-cooling Silencer 64 Ultra, Model "ACS64U" -RETAIL Item# N82E16835185110 Status: In Stock Save to Buy Later Remove Item $13.49 $13.49 Extended Warranty Coverage Memory (System Memory) Mushkin Dual Pack 184-Pin 1GB(512MBx2) DDR PC-3200 - Retail Item# N82E16820146299 Status: In Stock Save to Buy Later Remove Item $130.00 $130.00 Extended Warranty Coverage Motherboards - AMD EPoX "EP-9NDA3J" NVIDIA nForce3 ULTRA Chipset Motherboard For AMD Socket 939 CPU -RETAIL Item# N82E16813123230 Status: In Stock Save to Buy Later Remove Item $99.00 $99.00 **This item is warranted through the product manufacturer only. Extended Warranty Coverage Processors AMD Athlon 64 3200+ 2.0GHz, 512KB L2 Cache 939-Pin 64-bit Processor - OEM Item# N82E16819103500 Status: In Stock Save to Buy Later Remove Item $205.00 $205.00 Extended Warranty Coverage Extended Warranty: $ .00 Product total: $447.49
